Question about Miele M625EG Convection Microwave Oven
Miele M625 lightbulb replacement - Miele M625EG Convection Microwave Oven
  • Miele Master
  • 9,098 Answers
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
Often on a unit whose bulb is not meant to be replaced by the customer, the light is located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Posted on Dec 12, 2012
    New Friend:
The lightbulb fitted to a Miele M625EG is a bespoke design unique to Miele. To replace you need to remove the cover by unscrewing four "special" torx screws (thehave a pin in the middle to prevent the insertion of a standard torx key but you can break that off if you use a small hammer and chisel and a great deal of care).
You can buy a new bulb for an outrageous price at http://www.partmaster.co.uk/microwave/m625eg/lamp/product.pl?pid=2202211&shop=miele&path=110659&refine=lamp&model_ref=84142
KenC
Posted on Apr 04, 2014
How do I replace the lightbulb in a Frigidaire Microwave Model FFCE2278LS?
Good Evening Gary, thank you for your post!
From the information you have provided you need to replace the lightbulb inside of your Frigidaire microwave. I have researched your microwave and you are unable to disassemble your microwave in order to replace the lightbulb. In order to provide you with a proper resolution I would suggest seeking assistance from a professional technician for repairs. This will help you avoid unnecessary part purchases or personal injury. -Matt
Jun 13, 2015 | Frigidaire Microwave Ovens
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
What do i do?m625 eg miele oven smoke from top and turntable ceased working
Impossible to say what the problem is but if the turntable has stopped you could check the turntable motor. This is easily accessed from the bottom of the unit but you have to actually break the sheet metal tabs that retain it in place and replace using the screws only.
May 14, 2014 | Miele M625EG Convection Microwave Oven
Inside lightbulb went out
look at the top. there may be an access thingy you can remove to get to the lightbulb. replace the lightbulb with suitable replacement. problem solved.
Feb 16, 2014 | GE Microwave Ovens
The inside lightbulb went out how do we replace it?
open the microwave. If there is a removable panel on the top, remove it and replace the lightbulb.
Feb 16, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
Manual for miele s 334 i vacuum cleaner
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/miele/s_300i_s_318i_1.html
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 24, 2010 | Microwave Ovens
Replace a lightbulb in a microwave
That's covered on page 24 of the owner's manual.
If you've misplaced yours, you can download it online here.
If you need to order a bulb or other part or accessory, visit here.
May 31, 2010 | Maytag MMV5207A Microwave Oven
How do you replace the lightbulb on #5658972790
The light is located on the right side under the air duct attached to the magnetron.
See these files:
You can find handy exploded views like the one below at the Sears Parts Site.
Sep 15, 2009 | Kenmore Microwave Ovens
Miele M625EG Convection Microwave Oven Logo
286 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
