Question about HP P4515n LaserJet Printer
It has an error 50.2 is the problem in main board?
  • 24 Answers
50.2: Fuser warm-up service
Posted on Dec 12, 2012
Where is zsus board located
Samsung 50 Plasma Parts ' eBay
www.ebay.com/bhp/samsung-50-plasma-parts
eBayFind great deals on eBay for Samsung 50 Plasma Parts in TV Boards, Parts and ...Samsung 50" PN50C430 LJ92-01728A Plasma Y-Main YSUS Board Unit Motherboard.... Part Number: LJ92-01705C (Partial PBA number (705C) can be found on a ...Samsung HP-R5072 50" Plasma HDTV Main Board BN41-00632A ...
Samsung Buffer Board Test and repair Part 1 - YouTube
? 11:20
https://www.youtube.com/watch?v=5hVi5gd0aec
Oct 5, 2010 - Uploaded by z28r2fast4u
I checked two buffer boards and found 11 out of the 12 ic's bad.... my samsung, I post the video here, do you know how to test YMAIN and ZSUS ? .... Samsung PN50C450 with a bad Plasma Panel Shows how to replace the ...
Jan 18, 2016 | Samsung HP-R5072 50 in. Plasma HDTV
50 fusor error code for hp 3055 copier printer
Fusor needs to be replaced or error in Fusor section of main board
Jun 01, 2015 | HP Office Equipment & Supplies
Panasonci Viera 50
10 blinks is the Miscellaneous error code. Your TV knows something is wrong, but isn't sure what it is. It can be any number of things, including bad boards. Generally A red light blinking 10 times means that a video board has gone bad. viz.
Sub 5v SOS / Main 3v SOS DG Board/ DTV 9v SOS / Tuner Power SOS
Jan 10, 2012 | Panasonic Televison & Video
The color is distorted there is a psychedelic green around. You can see the color images ok but there is a super imposed green color on the screen. Do you have any idea on the problem do I need to replace...
The tv problems u are decribing are 50/50 it could be the main board tv Tuner signal board is dying and shorting out or the tv LCD screen panel itself are leaking radiation and slowly shorting out.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish main board tv Tuner signal board for the replacement.50/50 could get this tv fixed by replacing this main board tv Tuner signal board.If after u replaced the board and still have the same problems,than u know for sure it is the tv LCD screen is dying and leaking radiation and slowly shorting out.Than u know for sure this tv is not worth as a whole tv anymore,now only as salvages tv for it PCB circuits boards only.U can return the main board tv Tuner signal board to the dealers.Get some money back,but must lose some money,like subtraction like from the shipping and handleling cost and the useually the 10% restocking fee.
Aug 14, 2011 | Proscan 40LC45S 40 in. LCD TV
Hola tengo el problema de un codigo sc-322 en una ricoh aficio 1022
Laser synchronization error
Symptom:
The main scan synchronization detector
board cannot detect the laser
synchronization signal for more than 10
consecutive 50 ms intervals.
Possible Cause:
• Poor connection between the laser
synchronization detector board and
the SBCU board
• Laser synchronization detector board
out of position
defective
• SBCU board defective
• LD unit defective
Sep 02, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Kenmore oasis washer F50 error
I understand your frustration, error codes F 50 and F 2 run hand in hand. This is an error having to do with the main control board not communicating with the ccu. Usually F 2 is the control board straight up failing and F 50 can also mean the ccu is not understanding what is being said. The parts are usually 200 plus and with this error the ccu is probably part of the solution.
You can tell by this;
Control board is shot if: comes on by itself, changes spin speed even during wash, wash time freezing, beeping while all of this is going on and on occasion powering up to start a rinse cycle long after your done.
The ccu is harder to diagnose, usually erratic wash cycles of extreme imbalance ul error codes or over filling.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Vs450605 Misubishi
MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Also do you have a location number?
Sep 18, 2007 | Mitsubishi VS-45605 50" Rear Projection...
HP P4515n LaserJet Printer Logo
Seeker5211
Seeker5211
