Question about Refrigerators
Very slow at making ice
It takes a day for the machine to make a quarter bin
Ice maker leakes on bottomn frigidaire #240437101
Posted on Dec 11, 2012
  • Peter Gallagher
    Peter Gallagher Dec 11, 2012
    ice maker leakes on bottomn frigidaire #240437101
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: ZDI15 make too much ice
high level sensor is bad.
Posted on Mar 13, 2009
SOURCE: ice maker very slow to make ice
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
SOURCE: Have a Samsung RS2530 fridge
With your ice maker not working properly, you might be wondering the reason behind the malfunctioning of your ice maker. Several factors could be involved in case your ice maker is not making any ice as fast as you want. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off.
Next step would be to unscrew the copper line located at the back of the refrigerator. Now place the copper line in a bucket and turn on the valve to check if pressurized water comes out. The problem could also be linked to a defective tap valve. You could have it replaced. Since, freezer temperature can also be responsible for ice maker malfunctioning, make sure the freezer is not too warm.
Take care.
Posted on Sep 27, 2010
Make ice thenfull shuts off anddoes not come on ice starts melting
The bin thermostat or door switch is sticking. If it is an adjustable thermostat turn it clockwise a quarter turn.
Jun 24, 2014 | Manitowoc QY-0214A Self Contained Ice...
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
DC33 PA 1A
If the machines ice storage capacity is 26 lb per a day then that is all it will make in a 24 hr day Now this depends on water temp entering the machine, the ambient temperature around the machine and the condenser coil and fan is not dirty. Now the machine is capable of making 33 lb of ice in a 24 hour day but the storage bin capacity is only 26 lb if you don't remove any ice it will make only around 26 lb and shut off until it melts and causes the ice maker head to start.
Nov 26, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Slow ice production
that could be one solution. I would look at how long the freeze cycle is lasting. The machine could be cycling off and on via bin stat. Average cycles from start of freeze cycle to start of freeze cycle is usually around 25 minutes or so. If it is taking longer than that, you may have to dig deeper. let me know. Don't overlook a leaking water valve.
Aug 23, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
The icemaker in my freezer has a slow drip. The water then freezes in the ice bin. Why is it dripping, and how can I fix it?
Good day,
The most common reason is the ice maker is overfilling because the water valve in the bottom rear of the refrigerator leaks on the off cycle, and needs replaced.
Make sure the machine is level and the ice maker is mounted in the freezer properly to keep it level.
Also, make sure the fill pipe going into the back of the ice maker is properly positioned.
The Ice maker body could have failed but is very rare.
Nov 08, 2009 | Kenmore Refrigerators
Melded mass of ice in bin
The only thing I can offer is to limit the out put of the machine closer to what your needs are.Or bag the ice and store in a freezer. The ice pushing down while melting is what is causing the BIG FREEZE. The bin for storage may be too big for your needs, at least at the time you write this. When the demand goes up (warmer weather) the ice would be used more and the pressure pushing down will alternate as well as people getting scoops out more often this will help prevent such a freeze up in warmer weather.
Dec 01, 2008 | Scotsman Cooled Modular Contour Cuber Air...
No ice saved
If it's makes a good slab of ice the only reason it would melt would be a drain blockage holding water in the bottom of the unit or the water pan overflowing into the bin when it fills up. If you check the slab when it falls on the cutter and see a hollow looking spot in the middle you may have an evapoator leak. Yhis would require a service tech to repair.
Apr 22, 2008 | Freezers
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
