Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
I've replaced all the cartridges, cleaned the printheads and the page is still blank; is my printer broken?
There is a connection with my computer because sometimes I will get a blotchy copy with inconsistent printing. Now that I've changed the cartridges, the paper is all blank
  • 826 Answers
I think you need to change the printer......
Posted on Dec 11, 2012
  • 24 Answers
SOURCE: No PRINTOUT, only blank page/ no page received
Ink buildup in the internal service station causes the small poorly designed pusher cogs on two drive gears to snap off and the printer is instantly converted to junk.
HP was giving new printers out for this problem till Jan 06 or so as they realized it was a poor design.
I fixed one with parts from an electronically damaged unit, but usually the blinking lights and "won't print no matter what" problem are sheared gears. Parts are not available. Some people made metal gears (the only answer) on a very short run basis in Europe several years ago because people LOVE this printer.
Once you know the problem, it's simple to keep it from happening with some maintenance, but once they shear, it's over.
There was some kind of paper-clip fix that was solving the problem even with sheared gears, but I was never able to understand exactly how it was done. Needed a pic or two.
Otherwise a great printer, huge cartridges last a long time, great quality on photos too.
I have to keep mine running to have a happy wife.
Posted on Apr 05, 2008
SOURCE: printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Posted on Sep 09, 2008
jaznet
  • 75 Answers
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Posted on Sep 14, 2008
SOURCE: HP officejet Pro 8500 printer purchased May 31,
Replaced printhead. Problem seems to be solved. Will know more after see how long this printhead lasts.
Posted on Aug 15, 2009
don_farr
  • 1011 Answers
SOURCE: Poor print quality
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 17, 2010
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Blank pages printing
Sounds like the printhead is pretty severely dried. As standard cleaning cycles haven't helped I would recommend picking up some LC900 cleaning cartridges from eBay etc. These are cartridges filled/partially filled with cartridge flush and break down ink inside the printer.
Most of them contain a mix of ink and flush and you can carry on printing as usual. Given the severity of the dried/blocked printhead you have I would recommend just running cleaning cycles, but leave 10 minutes or so between cleans to avoid overheating the printhead.
Oct 16, 2012 | Brother MFC-5440CN All-In-One InkJet...
Printing blank pages
Hi
Check the ink cartridges installations.
Make sure there are no dry or damaged cartridges and replace if any.
Try cleaning the 'printhead'.
Mar 03, 2012 | Kodak EASYSHARE 5100 All-In-One Printer
Printer Page Prints out but Blank
Hi
Re-check the cartridge installations.
Try disconnecting the printer from power and then connecting it again.
Solved?
Mar 02, 2012 | Samsung ML 2010 Laser Printer
I replaced the black 100xl ink cartridge in my printer, it is almost full, and was working fine before, now it will not print and only gives me blank sheets. the colored cartridges work fine just not the...
Try to do the Deep Clean Printhead function on your printer. On the printer touchscreen, touch Ink Levels > More Options > Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please contact the Lexmark Technical Support Center or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Sep 12, 2011 | Lexmark Prospect Pro205 Wireless...
The printer sounds like it is printing but the page comes out blank.
Problem Blank Pages; Blank Print Out Solution
Symptom
When printing from the S or Pro Series printers, you may encounter blank pages being printed.
Solution
To rectify this issue, please follow the troubleshooting steps below:
Action Image 1
While on the main screen of the printer, open the cover.
  • If the printhead stays to the left, go to Step 2.
  • If the printhead comes to the center, do not continue troubleshooting because the printhead is faulty.
ss_mainscreen.jpg 2
Place the printer into "Replace Printhead" mode using the Maintenance menu. To access this mode, follow the steps below:
  • Touch Screen Printers:
    • Tap on the Ink Levels icon.
    • Tap on More Options.
    • Select Replace Printhead.
  • LCD Screen Printers:
    • Press the Setup button and use the arrow buttons.
    • Select Maintenance.
... 3
Open the covers and look into the printer on the left-hand side where the cartridges are inserted into the printhead - aWICKING PAD is located there.
  • If this PAD is BLACK (as seen in the right-hand image; click it for larger view), then the printer has successfully gotten ink into and through the printhead.
  • If the PAD is WHITE, then the printer has not been able to make the ink flow through the printhead. Go to Step4.
pad.jpg 4 Seat the printhead again. Unpower the printer and connect it again. Open the cover and reseat all four tanks. Press firmly on the rear of each tank and make sure all four snap in tight. ... 5
Insert plain paper and run Deep Clean.
    • Select Deep Clean Printhead.
    • Press the Setup button.
If you cannot get all four inks to lay clean, identify which one, if any of them, is failing.
  • If there is just some ink on the page - run the Deep Clean again.
  • If there is no ink at all, then the printhead is faulty.
Jul 17, 2011 | Lexmark Prospect Pro205 Wireless...
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Seeker5211
Seeker5211
