Question about Samsung AQV18NSD Neo Forte 18000 BTU Single Zone Ductless Heat Pump Mini Split Air Conditioner System
Lights blinking Water is leaking from the unti when turned on cool and sometimes it stops and the green lights blink
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: both of the green lights of my samsung as09xln
Try turning the power off for a few minutes and then turn it back on...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
  • 674 Answers
SOURCE: split a.c.1.5.ton, yesterday night stopped.
Somewhere on the cover or the circuit board there should be a chart that tells you what the different light combinations mean. Look around inside the unit and try to find the codes and you can also check the owners manual.
Posted on Sep 05, 2010
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Saeco magic machine, all the lights are blinking. Turning the machine off makes no difference. Can't make coffee. occasionally if we run a cup of coffee it will stop the blinking, but now that does not...
If all the lights are blinking in a row then you have a Main electronic board problem. Most common issue is that boiler has leaked water on board and caused it to fail.
Mar 23, 2010 | Saeco Magic De Luxe Espresso Machine
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Ethernet light is green but continuously blinks is there a problem with modem or ethernet cable?
no, a green light means there is a connection with the network and dns server (gateway to the internet) information is sent allow this network in bundles called packets. Each time a packet is sent the green light blinks.....sometimes when many packets are being sent in succession the light will appear solid. so i wouldnt worry, the green lights on your router and computer are normal and you should become concerned if these lights turn yellow or stop blinking completely.
Good Luck and Please Rate This Post!!!! :D
Oct 14, 2009 | 2wire (1000-000057-000) Modem
Program light is blinking and will not turn off
Mak sure all pats are back together, grinder unti top to grinder unit, closed basket etc. If the beepin will not stop after that unplug unit for about 5 minutes then plug back in , once again making sure everything is closed. The beeping is to warn you that a part is not there and a leak is posible if tht the case. Hope that helps, Steve
Jul 28, 2009 | Cuisinart Thermal DGB-600 Grinder
Lights flash alternating between red lights and green lights
The EEprom (memory of the machine) has crash. Needs to be re-programmed or substituted.
May 18, 2009 | Krups Orchestro 889 Espresso Machine
After descaling stuck in infinite loop
How old are your machine?
How often do you descale the machine?
I think it can be the flowmeter in the machine that needs to be replaced.
Try to descale the machine to see if it help.
Best regards
/Mirran
Sep 07, 2008 | Saeco Caffe Charisma Espresso Machine
Samsung AQV18NSD Neo Forte 18000 BTU Single Zone Ductless Heat Pump Mini Split Air Conditioner System Logo
22 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
