Question about ASUS 15.6in A54C-TS91 Intel Pentium DualCore B960 2.2GHz 4GB DDR3 320G
Lose charging port - ASUS 15.6in A54C-TS91 Intel Pentium DualCore B960 2.2GHz 4GB DDR3 320G
    Novelist:
    Champion:
  • 233 Answers
For loose charger port, there is a article for you to check out:
http://www.chargerbuy.com/blog/dc-power-jack-repair-guide-do-it-yourself-instructions/
Posted on Dec 12, 2012
  • ASUS Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first. http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Posted on Dec 11, 2012
Tablet not charging
Check whether Charger is connected well and is functioning well.
If Charger is perfect.. check for lose contact of charger pin in Tablet Charging Port.
If both things well.. contact service centre..
Aug 17, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
What can I do ....myblackberry curve charges and light turns green but the screen does not come on
Hello Julie Webster it sounds like the phone is not charging. Plug your phone into your desktop manager for Blackberry if you have it. You want to save your information as soon as possible. If your curve still does not come on when it is plug into your computer then the charging port is either dirty or not working at all. The curve had an issue with it\'s charging ports. If is a Verizon phone the may be able to replace it. If this is not an option here are a few steps for you.
You need a stiff but clean toothbrush and can air. Take the brush and clean the dust and dirt out of the charging port. Do not blow into the charging port to long because when the can starts to feel cold you spraying to long. One more test to see if your charging port is actually charging. See if the charging port moves with the plug inside it. Don\'t be to hard on the port it can become lose very easily.
Jul 28, 2014 | RIM BlackBerry Curve 8520 Smartphone
My apple ipad is not reponding when iam charging it how do i reset it
If you charge your iPad on a power adapter, the iPad should respond while charging, except if your iPad battery is so low the apps need more power to run.
If you charge your iPad on the USB port of your computer, it is normal you cannot use your apps as the iPad is not only in battery charging mode but also in synchronizing mode with iTunes in the computer. You should lose the habit to charge the iPad on the PC and use a dedicated power adapter instead, as dedicated power adapters charge the iPad battery 2 to 4 times faster than the USB port of most computers.
USB port power: 2.5 Watts in general (5 volt x 0.5 A = 2.5 Watts)
iPhone charger: 5 watts
iPad charger: 10 or 12 watts
Jul 26, 2014 | Apple iPad 32 GB WiFi Tablet PC
Battery loseing charge have changed alternator and had new battery but its still loseing charge
There is something using the battery power once you are parked.
Check your radio is off, interior Lights are off (check all bulbs) check exterior lights are off (check all bulbs) Check nothing is plugged into the ciggerette port
May 12, 2012 | 1987 Vauxhall Astra
I am trying to locate the low pressure port on my 2000 Saturn LS. there is no cap on the only visible and accessible port I see. It is located in the front of the engine compartment (passenger side) but...
The high pressure port is much larger than the low pressure port. It is impossible to hook a charging hose to the wrong port. If the charging hose is leaking, it is either because it is not clicked all the way on the port or the charging hose connector is defective.
The high pressure port is located on the discharge hose just to the rear (driver's side) of the A/C compressor.
Jul 10, 2011 | 2000 Saturn SL
The charging port was lose to begin with whenever i would plug my batt. charger in it. then one day I was jiggling around to get the phone to charge pulled it out and pushed it in and one of the metal tabs...
Hello
If one of the metal is bent up and your phone is not charging then you would need to replace the charging port of your phone.Before replacing the charging port you could use a desktop charger for the main time while you get your charging port replaced.
GOODLUCK
Jul 02, 2010 | Motorola Mobility W385 Cellular Phone
I cannot charge the blackberry 8320 and the battery is new.It was charging just fine. I change the battery and the charger.and it still has the problem.
Hi, my name is jeff and I work for a used cell phone and repair store in Sioux Falls South Dakota called THE CELL PHONE GUY. what could be going on is that your charge port is broken or loose. there are about 4-8 prongs that are solderd on to your board, those will come lose or break from dropping the phone, hagining your phone on your charger, or just normal wear and tear of putting your charger in and taking it out. you would have to re solder a new charge port on there to fix that. luckily my company THE CELL PHONE GUY are highly trained in charge ports we have done over 2000 charge port repairs with 2 coming back on warranty, if you want us to fix it give us a call! 605 335 0411
Mar 17, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Shows Li-On battery charged when plugged into AC, shuts down when unplugged
Here is a palm article on the battery not holding charge-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=42,E=0000000000826384196,K=1280,Sxi=19,Case=Obj(30029)
My battery loses its charge very quickly
Like all Lithium Ion batteries, the battery in your device will eventually wear out. If you charge your device fully but it loses power after a few hours (or sooner), it may be time to replace the internal battery.
Sounds like you already did this. Do you have someone you know who has the same battery you could try? Or try your battery in their device?
Also this site looks good -
http://www.ipaqrepair.co.uk/ipaq_battery.php
Step #11
You can connect it via USB and let it charge that way a little while, then try charging it normally. It's called trickle charging-
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
Dec 30, 2007 | HP iPAQ RX3715 Pocket PC
ASUS 15.6in A54C-TS91 Intel Pentium DualCore B960 2.2GHz 4GB DDR3 320G Logo
224 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
