Question about HP "MITSUMI D359M3D 1.44MB 3.5"" COMPACT FLOPPY DISK DRIVE 1-INCH HEIGTY"
Floppy driver mitsumi d359m3d - HP "MITSUMI D359M3D 1.44MB 3.5"" COMPACT FLOPPY DISK DRIVE 1-INCH HEIGTY"
Why my "MITSUMI FLOPPY DRIVE" not recognized in windows 8
You might have a driver issue, check if the manufacturer has a specials driver for Windows 8, it should work straight out of the box unless you have a connection cable issue, or you might have killed it if you wasn't wearing anti static gloves.
Apr 27, 2016 | Mitsumi (11-08004) (1108004) External...
External floppy drive does not work on this pc but on others
Hello!!!
You have to install the drivers which has come with the external floppy disk!!!
Jul 31, 2008 | Mitsumi (11-08004) (1108004) External...
Mitsumi D359M3 driver for Win Wista, 7
You shouldn't need one. You PC bios should pick up the drive when you turn your PC on.
Look in "My Computer" the floppy should be listed there.
Floppies only hold about 1.44 Mb of data Its worth mentioning that these drives are more or less obsolete now, flash/USB drive hold much more data, more now than CD's (700Mb) and
DVD's (4.7 Gb) and now with SD card usb adaptors almost as much as Blueray disks (25 Gb)
Aug 26, 2011 | Mitsumi (D359M3 SILVER) Internal Floppy...
Can't find drivers for mitsumi floppy drive D3553FUE
floppy drives are installed on most newer operating systems. When installing a floppy drive, you do have to be certain the floppy driver is enable in the system BIOS. That is generally the problem when you cannot get a computer to recognize a floppy dirve.
Dec 23, 2010 | Computers & Internet
Windows dectect my floppy mitsumi d359m3 but did install driver or could not find it
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 21, 2010 | Mitsumi (D359M3 SILVER) Internal Floppy...
Drivers for floppy disk drive mitsumi d359me
I guess the problem is that it does not work? Go to goodwill and buy another or purchase and external USB-Floppy.
Jan 26, 2010 | Mitsumi (D359M3 SILVER) Internal Floppy...
Brand new Mitsumi internal floppy drive not recognized by Windows
Check the BOIS setup. Press on boot and see it the Floppy drive is turned on.
Mar 05, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
I need to know the voltage of Mutsumi D359M3D floppy and where?
The power cable connector to the drive has 1 red (5v DC), 1 yellow (12v DC) and 2 black (common center or negative) wires feeding the required voltages from the main power supply source. The power connector will only go on one way. I hope this helps.
Mar 01, 2009 | Mitsumi (D359M3 SILVER) Internal Floppy...
External floppy drive does not work on this pc, states it's missing code37
Try unplugging computer power cable for 10 minutes, if computer is a laptop also remove battery for 10 mins, so to cut power to computer, this will solve problems caused by electrostatic charges on computer usb.
If it still does not work, than it means that windows drivers for usb are not working properly, in this case you will have to reinstall the system.
HP "MITSUMI D359M3D 1.44MB 3.5"" COMPACT FLOPPY DISK DRIVE 1-INCH HEIGTY" Logo
89 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
