Question about Whirlpool Refrigerators
Whirlpool refrigerators defrost button got stuck what to do?
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: semi automatic defrost button won't pop up
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Posted on Dec 09, 2008
  • 2696 Answers
SOURCE: Whirlpool refrigerator seems to be
you have to send model number,if you know where the timer is advace it by hand and if it clicks out of defrost you have a bad timer or if it has a adaptive defrost board change it out
Posted on Nov 21, 2009
  • 2696 Answers
SOURCE: refrigerator keeps defrosting and depositing water in fridge.
if your food is staying cold your fridge is working fine,you probably have a blocked drain.you will find water under criper draws and maybe leaking out on floor,take off the back freezer wall and take out floor, melt out the drain and remove all the ice on freezer floor,now you have to clean out the drain,i use a steamer that you can buy for like 40 bucks,it's a shark super steamer,it will clean out all the slime that builds up in the drain line or you have to snake out the drain line with a plastic tie or something,when you think you cleaned out the line pour hot water into the drain and if the water goes down you know you unclogged it,you can buy a heater probe that installs down the drain and wraps around the heater so the line can't freeze up again,if this is not your problem you can advance the timer in the fridge side on the ceiling by turning it with a screw driver until it comes out of defrost and if it was sticking or not coming out of defrost on it's own change the timer the new part number for your timer is 2183400 hope this helps
Posted on Nov 24, 2009
My whirlpool refrigerator freezer section around the blower fan is frosting up I changed the defrost heater and it still the same model number wrf560seym00. What next to try.
You may have an air leak around the door seal or the ice chute door is stuck slightly open causing compressor to run all the time as moisture from outside fridge to collect on fan shroud and evaporator. Are you defrosting normally or temperature rising inside fridge?
Appliance 911 Sea Breeze
Sep 18, 2015 | Whirlpool Refrigerators
Refrigerator is too cold! Freezing everything
The defrost timer or thermostat is probably stuck. It is located on the bottom of the fridge. look at pictures of a defrost timer on several parts site for appliances. $30 and easy to replace.
Oct 20, 2014 | Whirlpool Refrigerators
My freezer is not working its defrosting everything. Is there a reset or something I can do to fix it?
No reset button . Having no model number I gotta guess your timer is stuck in defrost. You must find the timer and advance it into the RUN mode. If the timer is good I would next take a look at the relay on the compressor. They fall apart overtime:
If this is one of the fancier ice boxes with auto defrost mess
then your thermistors could be bad or control board gone south. More Here
Sep 03, 2011 | Whirlpool Refrigerators
How do you fix a refrigerator stuck in the defrost mode
Hi, You will need to change the defrost timer/board which ever you have... in the meantime a whap with your hand on the side of the fridge or unplugging and restarting may help....but the fix will only be a temporary one...next time it goes into defrost it may hangup again...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 24, 2011 | Whirlpool Refrigerators
The refrigerator won't turn on when I plug it in. Any idea what the problem could be?
Defrost timer could be in defrost cycle and stuck. You may have to replace it. if you have no light, no compressor noise and no fan running inside, it is a defrost timer, bad plug or no power.
Oct 13, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool model ed5fhgxkq03 side by side. Lights
check your temp controll to make sure it isnt broken or open circuit also your defrost timer could be stuck in defrost! next check your compressor for running and see if it is hot!! or just warm? if it is just warm and cycling /running then your low on freon due to a internal leak
Jan 14, 2010 | Whirlpool ED2FHEXN Side by Side...
Frezzer stuck in defrost cycle
You have a bad thermostat . The piece the refrig temp knob is on ( not the freezer knob , it works off an adjusting rod ) .
Nov 12, 2009 | Kenmore Refrigerators
Semi automatic defrost button won't pop up
This happens a lot
Huum
This is the answer.
click solve please1
Dec 09, 2008 | Refrigerators
Refrigerators Logo
389 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
