Question about Robert Bosch Ltd Bosch Ptk 3.6 Li 3.6V Lithium-Ion Cordless Tacker
A spring came out of my bosch PTK 3.6V staple gun. I opened it to see where to put it back and two other springs came out. Anyone got a diagram I can use to try to put it back together?
I'd like a diagram to put it all back together again.
I removed top spring how do I reinstall and load spring
were you reloading the staple gun, now you want to put the spring load back in it to lock it to use it? slide it in, and push downward to lock it in.
Sep 27, 2012 | Arrow T25 Staple Gun
How do I load staples into my JT21 staple gun?
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Mar 17, 2010 | Stanley Tools/Goldblatt Tool No.TR150 Hd...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
May 10, 2009 | Tools & Hardware - Others
There is a Stanley bostitch model B2000 stapler in my classroom. I need to fix the spring that advances the staples and holds them in place! wehre do connect the spring?
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
Feb 25, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Nov 08, 2008 | Powerfast Stanley TR110 Light-Duty Staple...
ASSEMBLY
I just had to repair one of these guns for work. It's a bit tricky, seeing as you are dealing with springs and such...but it can be done. Take your time ...don't set the springs until you have things set in place and lined up. Make sure the pins are in place. Set the flat spring first (it is the toughest) while the handle is depressed all the way in. Gently open the handle and then set the torsion spring. Take your time here...springs are set and they could make all the pieces fly out if you don't quickly get the other half put on it. Hope this helps.8d59edb.jpg
Aug 21, 2007 | Black & Decker 5700 Powershot Forward...
Robert Bosch Ltd Bosch Ptk 3.6 Li 3.6V Lithium-Ion Cordless Tacker Logo
64 people viewed this question
Top Robert Bosch Ltd Saws Experts
Tom Chichester
ray gallant
Are you a Robert Bosch Ltd Saw Expert? Answer questions, earn points and help others
