Lcd not functioning no display, but computer is still working
Machine will run but if problem arise cannot display the cause of stoppage on the machine
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Dec 11, 2012
Ihave canon ir 400 machine but thats no worked. machine displayed error cod E805 .sir please give me sugestation
E805The stoppage of the exhaust fan is detected, or a failure in rotation of the fan is detected. (iR/GP400 or later machines)The detail code, which can be checked with DISPLAY,
You can try to clean up the fan
Apr 14, 2018 | Canon Office Equipment & Supplies
The water comes out in the detergent/softerner liquid dispenser; instead in the main washer.
Water Problems
Sometimes water will not enter the machine in order to properly wash clothing. In that case, the water may be turned off or the water fill valve, water temperature switch or timer may not be functioning correctly. A defective water valve or timer can also cause the machine to not enter the spray rinse cycle. Another issue that arises is when the water will not drain out of the machine. The drain may simply be clogged, or the drain hose or pump may be malfunctioning. Water will splash on the floor if the pump or water valve is not working, or if the machine is operating on a low level of water with a high level of agitation, which means the force that promotes all the functions of the machine.
Cycle Problems
Malfunctions of the various cycles are common as well. If no agitation occurs, the agitator spine may be stripped, or the motor or internal transmission system could be broken. If the machine will neither agitate nor spin, the belt or coupling is most likely the problem. There are a number of issues associated with either no spin or a slow spin including an open lid, defective lid switch, spin tube, wigwag, timer or wigwag wire or a drive belt that is not properly adjusted. When the motor will not run at all, first check the power cord to make sure that it is plugged in. If that does not solve the problem, issues are found in the timer, lid switch, motor or water level switch.
Other Issues
Sometimes washing machines will excessively vibrate or "walk," meaning that they begin to inch forward while the motor is running. Check inside the machine to see if there is an unbalanced load. Heavier items, such as sneakers, cause vibration as well. The load can be fixed and any unnecessary items removed. If the problem persists, other possible issues include an improperly leveled machine, a worn-out snubber, broken suspension springs or shipping pins that have not been removed. Another problem that arises with washing machines is oil leakage caused by transmission failure, which is one of the more costly issues to fix.
Cycle Problems
Other Issues
Mar 12, 2011 | Washing Machines
Hi i have got 1997 subaru Legacy, the internal air function was working fine, till last week, but sudenly, it stop working. I can see the display, but the air is not comming, not for the Aircond. and not...
Is this A/C or entire climate control problem? I have a 97, too, and took out my climate control unit and found debris and spilled liquid on the unit! Liquids play havoc on electrical connectors. Make sure all connectors are clean and thoroughly connected to housings. Check the harness for breaks in wiring. Could have a short someplace. Heat and/or too much current could possibly cause immediate stoppage. Never forget simplest method..... check the fuses both inside car and under hood. If it's A/C as the problem, check R134 level at certified mechanic. Don't run A/C with low coolant - could burn up compressor. Let me know how it goes!
Oct 04, 2010 | 1997 Subaru Legacy
Whirlpool duet frontload dryer stops running after several minutes of drying. The door seems to pop out enough to cause it to shut off. There are no codes showing or anything. This is a brand new unit...
If the door is popping open, that is causing the stoppage. There may be a way to adjust it, but I would have the people you bought it from fix it!! Best to have the device (spring/clip) that holds it closed replaced so it will give you longer life.
Peace,
Mar 07, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Computer freezes
make sure your CPU fan is functioning correctly, this happens generally when the CPU is overheating due to fan problems or stoppage. If the fan is ok, and the CPU is not overheating, try a different memory, one of will work.
helpful ? if not reply and i'll give you other hints
Mar 23, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Acer LCD Monitor - Stuck Displaying green
Cant say for sure. The display seems to be working, and the computer signal seems to be the problem. It could be a faulty cable. Check the pins on the cable monitor and see if they are bent, etc.
If the connectors are Ok, it could be the converter or the main board that has the fault. This could be caused by a power surge, or just a mechanical failure.
There is no easy diagnosis for this\ one, without actually checking the parts. I would recommend taking it to a repair place.
Jun 03, 2008 | Gateway FPD2275W LCD Monitor
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
BLACK OUT LCD DISPLAY AND PANEL NT FUNCTIONING
hi,
seems like a silly question, and i dont know about canon copiers, but on my toshiba, underneath the key panel there is a scroll button that turns the brightness of the lcd up and down, if hit by accident, as often happens the lcd appears black. It has tricked me before!! haha
Take care
Apr 01, 2008 | Office Equipment & Supplies
Cannot turn mfc-665cw off
Hello Katie.
What is the problem you encountered, If cannot turn off the printer may just simply unplug the power cable from the outlet.
disconnect your printer prom the pc. If you want to use it again just simply plug to the power outlet and connect the printer again to the pc. don,t forget to restart the computer so that the system is alwasy fresh as you work on.
You know i need you to elaborate what is the exact problem of your printer.
If any problem arising please notify me for further instruction.
best regards, melnavz.
Feb 23, 2008 | Brother Multi-Function Center MFC-665CW...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
