Question about Drills
Hi. I was drilling a few holes in concrete with my TE 56 HILTI and the drill bit become jammed. it began to smoke so i put a new set of brushes in it and still the same spins slow and smokes, any suggestions????
    Champion:
  • 304 Answers
It sound like is has overheated or a bearing has seized. Take it to hilti. www.hilti.co.uk for nearest dealer. They will collect for a price.
Posted on Dec 18, 2012
3 Suggested Answers
  • 165 Answers
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Posted on Feb 27, 2010
  • 123 Answers
SOURCE: will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
Posted on Mar 05, 2010
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Mar 01, 2011 | Hilti Drills
I am looking 4 brush,s 4 the te-15 hilti hammer drill, 2 sets, 4pcs ...
In US contact Hilti @ 1-800-879-8000
TE 15 Brush Item # 71781
Sep 16, 2010 | Hilti Drills
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
My Hilti Te 52 hammers hard for a minute and then stops. The motor keeps turning, if you lift slightly on the bit it'll start hammering again. After another 20 seconds it'll stop again. You can drill a...
It does sound like the clutch is worn out. You would have to completely disassemble the whole tool just to get to the clutch. Then there are no parts available.
While the 52 was a very good drill the clutch had a tendency to wear out. I know it is hard to give up on a tool that is still working halfway, but the tools made today are much faster than the 52.
PS if you look to purchase a new one from Hilti they always offer a trade on your old one.
Apr 03, 2010 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
When drilling in precast concrete, Does it take a special concrete bit?
It depends on what kind of fastener you are going to use, a split bolt is different that an ancor bolt and the need different size holes. so tell us the type of anchor bolt your using.
Jan 05, 2010 | Hammer Set Of 4 Hilti Concrete Drill Bits...
Trying to drill a solid concrete 10 inch wall
the ideal sollution is to fully service the machine but there may be a quick fix.
remove the 4 screws that hold the black plastic handle assembly, and take the handle off. on the top of the drill you will see an oil filler cap. unscrew using a 10mm allan key.
empty out any old oil. rinse out with some parafin if you like. empty out again . put some new oil in and replace the cap. 50cc of transmission fluid / power steering oil will do the trick. if this dousnt fix it then you will need to replace the o-rings on the pistons, if this is the case, drop me a email and I will send you a parts diagram. paul@wysehire,gi
good luck.
Jun 02, 2009 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
Drills Logo
150 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
