Question about Transcend T.sonic 850 Digital Media Player
Mp850 is not being recognized by my computer. How is that possible?
After the mp850 is connected to the computer, its battery is seen charging. But my computer is not being able to identify it? Why is that?
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
70d
If you get an error when you connect then there could be a driver issue. If the camera isn't seen at all be sure the USB cable is good, batteries charged and camera is turned on AFTER you connect to the computer. Also try a different USB port on your computer.
Mar 16, 2014 | Canon Cameras
My ipod not recognized by itunes in order to reinstall the software
Connections b> The USB cable must be securely connected both to the iPod and to the selected USB port on the computer. Reattach the cable at both ends, and click "Computer" in the start menu to see if the iPod is shown connected to the drive for that USB port. b> Drivers b> If the drivers of the computer responsible for the USB interface are out of date, malfunctioning or incorrectly installed, that may also cause the iPod to not be recognized by the computer. If this is the case, the device may not appear in iTunes and there may be an exclamation point next to the device in Device Manager. b> Software b> The latest version of iTunes is recommended to best communicate with the various models of iPod. Go to the iTunes website or click "Help" and "Check for Updates" in iTunes to install the most recent update. Further, the computer must be running Windows XP, Vista or Windows 7 for PCs, or OS X v.10.4.11 or later for Macs. b> Battery b> The iPod's battery must have sufficient charge to be recognized in iTunes; charge it either via USB connection or another power source if the indicator shows a low battery. Once the battery has charged, try to connect the iPod to the computer via USB cable again.
http://support.apple.com/kb/TS1538 Ipod not recognized http://support.apple.com/kb/TS1495 Device not recognized
Jan 24, 2013 | Apple iPod classic MP3 Player
Won't come on after charging in usb hub
Depending on how long you've had the player, the batteries may need replacing.
I have seen a problem where the computer would not recognize the player and would not charge it, however.
First, I recommend trying to charge it directly from the computer USB port (not the hub) if possible. If that doesn't help, try reinstalling the software for the player to see if the computer will then recognize it and allow charging.
If neither of these fix the problem, it's probably time to replace the batteries.
Jul 13, 2011 | MyMusix PD-6070 MP3 Player
When i connected the transcend ipod mp850 4 gb to the computer it is showing wait symbol and it is remainig the same from the hour of i purchased ...so plz tell me a solution for this......
The problem is with the computer. Update the driver, Or put the Software CD of the player, and now it will work fine.
Cheers...!
Mr.Maduraikaran.
Dec 24, 2009 | Transcend T-Sonic 850 Digital Media...
Just purchased a compaq presario secondhand--is the battery supposed to charge automatically when you plug the computer in? Mine is not. Works perfectly with the power cord though.
All the laptops I have seen since the 1980's charge the battery, if it is installed, while the laptop is running. They charge at a slower rate if you are using the computer, and faster if you just plug it in and leave the computer powered off.
Most have a 'charging' led [green or amber] indicating that the battery is being charged when you plug the laptop in and leave it turned off. If you don't see any indication, check that the battery is connected firmly and that the connectors are not damaged. If possible, try the battery in another machine or a different battery in your machine.
tom
Dec 21, 2009 | HP Compaq Presario V6000T Notebook
Ipod not charging
it may be possible that your itunes does not recognize your player becauseno power remains in the battery. try charging your player loner or if it doesn't work that way, have the battery changed
Mar 10, 2009 | Apple iPod nano
Battery not recognized
If the battery is beyond charging, it might not be recognized but, all that I've seen could recognize it . There are 6-8 terminals on most batteries. 2 of them close the circuit indicating a battery is in place. If you have access to another battery that is made for your computer, try it. If you still don't have a battery indicated, you could have a problem in the charging system or the bios.
Feb 20, 2009 | Dell Inspiron B130 Notebook
Presario V2000 battery not recognized
you may need to have that battery charge for a while, until it can be seen at charge level..or simply check the connections to see that there is no junk in the connector..
Nov 21, 2008 | HP Compaq Presario V2000 Notebook
Transcend T.sonic 850 Digital Media Player Logo
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
