Question about HP PSC 2210 All-In-One InkJet Printer
PROBLEM WITH RECEIVING FAXES
After losing my patience when I kept getting the message check align cartridge I pressed every imaginable combination of buttons on my HP all in 0ne psc 2210 printer until I found out that I needed to replace the colour cartridge before my black cartridge would work. Now I find that all incoming faxes simply print a page covered in BLACK INK. Could someone please help me as I am losing my incoming faxes and cannot get them re-sent as I do not know who they are from. Help! Help! I am ready to throw out the printer and move to another planet. vera
    Scholar:
  • 77 Answers
You can't move to another planet unless you take me with you! A couple questions, please. Can you make a copy? Did you replace the cartridge with a NEW HP branded cartridge? BTW I've never left the States, but if I did NZ is the first place I want to see. Is it as great as I imagine it? Let me know the answers to the first 2 questions anyway Thanks, Ed
Posted on Jun 12, 2007
SOURCE:
How to print faxes from the lexmark x5630 which is stored in the memory
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
Cant send faxes
It sounds like the faxes memory is full, either from receiving or transmitting faxes, try turning it off and on again, the fax might just need to recognize you have installed a net toner cartridge.
Oct 16, 2009 | Office Equipment & Supplies
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Jul 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
The display shows "Press Enter to align cartridges." (I had installed two new ones.) No matter what I do, the messages continues--can't print, can't get it to stop.
It has to complete the alignment procedure to continue. If any colors or black ink is missing it won't be able to complete the alignment. You can also press a combination of 2 keys to bypass alignment but the message will return later.
Jun 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
Do not see align or clean catridges at preferences /features
hi,
To Align the cartridges, please perform the following instructions.
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page
Regards,
Sagarjd
Nov 21, 2008 | HP Photosmart C4180 All-In-One InkJet...
Color not printing
If you are making copies or sending/receiving faxes Press Black Start or Color Start. Make sure your ink cartridges are fresh. Cartridges remain fresh for up to two years if kept in their original packaging, after that the ink may become clogged. Cartridge expiration dates are printed on the package.
Sep 01, 2008 | Brother MFC 210C All-In-One InkJet Printer
PSC 2115 error message
turn off your machine unplug the power for about 5 mins. disconnect the usb cable from back. Plug back in power, wait until machine fully boots up. Check your cartidges to make sure there in there good and are not lose. Remove them and just put them back in making sure there secure. Then try to aline the cartidges.
Feb 16, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
HP PSC 2210 All-In-One InkJet Printer Logo
46 people viewed this question
Clive
Clive
Thomas F. Schneider
