Question about Uniden BC244CLT Base Scanner
I have a 3500xlt i have programed in channels it scans i can hear the diff in background noise in am fm ext but it wont rec any sig am i doing something wrong or is the scanner defective
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: Can i program my bc355c scanner to scan only the
Yes, once you have programmed/transferred frequencies into the PRIVATE bank, with the scanner powered ON, press the PRIVATE key to start scanning. Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC355Com.pdf
Bill B.
Listening in since the 60's
Posted on Feb 01, 2011
  • 41 Answers
SOURCE: have a new uniden bc355c
With all due respect, I suggest reading the user manual that came with your scanner. The user manual is the best reference material there is. for this product. If you need frequencies go to www.radioreference.com
Posted on Jul 13, 2011
Setup wizard
what do i do fix this ?
Dec 06, 2013 | Westinghouse Televison & Video
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
Auto muting on when on am/fm and no sounds come out. everything else is fine.
That's normal.
The Auto Muting mode mutes the audio output of the tuner if the station is not sufficciently strong to be accurately tuned. Otherwise you would hear all that interstation hash noise.
Press the FM Mode button to change it to Mono if you want to manually tune a hard-to-reach station. It will be in Mono.
Page 26:
AUTO MUTING
Normally select this.
When a program is broadcast in stereo, you will hear stereo sound; when in monaural, you will hear monaural sound.
This mode is also useful to suppress static noise between stations. The AUTO MUTING indicator lights up on the display.
Mar 31, 2010 | JVC RX-D205 7.1 Channels Receiver
When in the MO mode, I hear nothing. In the FM mode, I hear everything. I want just to listen to local FD. I have their codes loaded in. Just doesn't seem to scan the channels when in MO. What am I doing...
MO is for monitoring MOtorola trunking systems and will only work if you have programmed a system into your scanner. Most fire departments are using conventional, (FM) transmissions, not trunked systems - mainly so that volunteers and neighboring departments can follow the action and respond if needed. For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Need the manual for your scanner? You can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-96/pro96.pdf
Bill B
Feb 21, 2010 | Radio Shack Pro-96 Scanner
When switiching on the TV and selecting channel 6 (s/b Sky) all I get is a blue screen to get to the sky channel the ext button has to be pressed to take it to ext2. How can I get the TV to remember the...
You must have channel 6 programed to first ext when you turn TV on it seems that it is programed on ext2 instead of ext Go to Menu then do Auto Program when you have it on ext and make sure your inputs are on first ext and not ext2
Nov 22, 2009 | Toshiba Televison & Video
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
It will scan but not hold a station
Hi
i think the fm settings is not lock in to fm scanner! or program the fm station then lock it in ti memory
Thanks!
Jun 05, 2009 | Coby CX-61 FM Radio
Sony ICF2010 Scan does not work.
The SONY does not scan non programmed memory channels, you must have some programmed in.
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
I recently bought a Sony STR -DG820 and hooked up everything using HDMI cables and I am having touble with the sound. I can hear on some channels, but not others. The channels that are having the audio...
hello to ensure your`re having good sound. hook up in other way not using hdmi cables,the background noise usually indicating a good carrier frecuency but no clear check good cables,not pinched,broken or if it has radio the air antenna or fm....if you got good sound now use the hdmi cables and take a close look in the connector if all pins are good at each end saludos
Jan 17, 2009 | Audio Players & Recorders
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
Oct 13, 2008 | Kaito KA1103 SW/FM/AM Radio
Uniden BC244CLT Base Scanner Logo
35 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
