Question about Graco Century Fold N Go Playard Sheet Merlot Plaid
My century fold-n-go side rail won't lock what do i do?????
Top short rail won't collapse
Here is a link to the instruction manual for the Pet Pen. i hope it helps you to work out the problem. If that still doesnt' help, you should go back to the place that you bought it and ask them for help
http://www.petgearinc.com/Instructions/33/Product%20Series-PG4200%20PG4400.pdf
Oct 08, 2012 | PetGear Home N Go Pet Pen - Large
2003 Buick Century. drivers side window won't work and window lock won't work all other windows do work. All the other windows will work whether the window lock is on or off. Also, dim lights on...
Time to wander through the spaghetti of wires and contacts with voltmeter looking for a closed circuit to ground. Sounds like the radio is where to start.
Oct 30, 2017 | 2002 Buick Century
1990 Buick Century Custom 4-Dr Sedan 3300 V6. New motor, fuel pump, fuel filter, alternator and starter. Turns over, though it won't fire.
Check your fuel pressure at the schraeder valve that is on the fuel rail. If you have fuel pressure, check for spark.If no spark, then ignition diagnosis is needed.If no fuel pressure, check for diconnected, or pinched wires, as this can easily happen during an engine swap.
Aug 14, 2011 | 1993 Buick Century
1996 Buick Century--the transmission is locking up if you are moving and hit the brakes, but if you put it in neutral and rock it back and forth it will start moving again, sometimes. It sounds like the...
The odds are that it will have to come out
& be rebuilt
Even when you do that, you usually don't
actually find much,but the issues go away.
I once owned a trans shop
May 29, 2011 | 1996 Buick Century
Cant lock the end rails of the porta-cot, the two side ones lock in fine but the end ones just fold back down. Its a Jeep Sahara Limited XT playland.
Before you lock the bottom of the playard, you need to pull all the way up on the two side rails, they will form a slight arch, and the button will click into place. Then push down on the bottom rails.
Feb 06, 2011 | Kolcraft Jeep Sahara Limited Xt Playard
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
Where is the fuel pump oo 93 buick century v6
Fuel pump is in the tank, fuel filter is along the subframe rail by the rear wheels, either left or right side.
Mar 17, 2010 | 1993 Buick Century
Not locking have to manuely lock from inside the car
the wires in the trunk lid are broken. this model has poorly designed electrical. there is a wire bundle on the right hand side of the trunk lid open the bundle up and resplice the 4 wires. this will correct the doors and remote trunk opener.
Feb 16, 2010 | 2000 Buick Century
Can't get sides to stay up (lock) on our Century fold n go lullaby center
I had the same problem until I found the manual and practiced a bit, When opening, it's important for the middle to still be in a high unlocked position - then they click right in place very easily. The sides won't go up if the center column is down too far first because the middle locks in place automatically and prevents movement of the sides.
When folding it, the floor lock has to be twisted fully in the unlock position and the center column back up in a high position for the sides to fold in (each side as 2 joints to disengage). Unlocking turns the center support column so that all the support tubing underneath can move. If the center column won't come up high, you don't have it unlocked yet.
Here's a Century Fold N Go instruction manual.
http://www.gracobaby.com/Instruction%20Manuals/archive/10765.pdf'
To look for different models
http://www.gracobaby.com/customerservice/productinstructions/Pages/default.aspx
Jul 28, 2009 | Baby Gear
Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Graco Century Fold N Go Playard Sheet Merlot Plaid Logo
335 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
