Question about Nokia C5 Cell Phone
I want to dirvert some number how to do that
    New Friend:
    Problem Solver:
  • 5 Answers
You should be able to hit option oh the number/person and click block call.
Posted on Dec 11, 2012
I want to dirvert calls to another handset plerase help
go to the call settings then click on the call divert option then click divert all voice calls then on that select the option as divert to another number then feed the number inside the tab now click ok check the status now if it says activate then its ok. If not activated then contact your service provider to activate the call divert for your number . because they may block divert optoin for your number
Jun 15, 2011 | Cell Phones
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
Water comes out both spout and showe head when temperqture control is adjusted
Something is blocking the flow thru the tub spout. Make sure the dirverter moves properly. It mat be stuck partialy closed.
If that does not work take the tub spout off and see if you still have the problem. If that fixes it get a new tub spout.
Mar 31, 2011 | Delta & Lockwood& Tub & Shower Faucet
Heater lights for about 4 to 5 sec. then gas shuts off,
You may have spider webs in the gas orfaces. Pull the tray and unscrew the orfaces from the gas manifold then clean with a toothpic or the like, These will be very small webs and are hard to see but they dirvert gas from the burner with the ignitor and when it does light the ignitor can't reconigse the flame and it will go out. i've seen this happen after the heater is off for the summer season and I've seen it happen ovet night. This iss one of the things you can avoide by cleaning and serviceing the heater once a year. i hope this was a help.Good luck
Sep 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Water coming from faucet and showere head when the
the washer on back of the dirverter knob needs replacing or the seat behind the vavle stem
Aug 18, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Model JPX-300H, the unit does not fill, but it will drain if you fill with water from a bucket. Also when the unit drains there is water coming from under the unit. How do I check the fill valve for proper...
the fill valve is easy just take the coil off and there is a hole in it put a metel screwdriver in the hole and turn the unit on if it pulls the screwdriver like a mganet it works is more likely i bad diaphram now as for the draining it drains bu turning a valve dirverting the watter from the pump down the drain hose so you must have a hole or leak in the hose
Aug 06, 2009 | Jackson 24 in. JPX-300H Built-in...
I seemed to have lost the "turbo" that gets me up the hils where I live. I recently had a timing belt change and get regular maitenance every 10,000K. Also I have had an undiagnosed "shuddering" for the...
If it's a TDI, then your intake is probably clogged. If it's a 1.8, then check your turbo hoses to make sure they are all connected. Check Dirverter Valve.
Jun 27, 2009 | 2003 Volkswagen Jetta TDI
How to connect laptop to projector?
Data projectors have a video cable and you connect it to the 15pin blue video connector on the laptop. Then you power up the projector and then power up the laptop. The laptop should automatically dirvert the video information to the data projector.
If the image produced from the projector is not clear, then you will need to reduce the screen resolution on your laptop using Control Panel - Display - Settings.
Mar 30, 2009 | Fujitsu LifeBook A6110 Notebook
The telephone has no dial tone and I wish to have my calls dirverted to my mobile which is 0277556905 I have been waiting for 18 and a half minutes for assistance but am still on hold. The number in...
Which phone company are you using?
Is your call set for call al art by you phone company?
If your phone has no dial tone, have you check the phone line that is coming from the wall jack into your phone.
call your services provided to direct all calls to your cell.I believe they charge extra for this service.
Thanks
Good luck
Jul 30, 2008 | Lands Phones
Can not align color dirvertions on test screen
I think you need a remote to use the convergence features of this set. Does it have an auto convergence feature? And does it work?
Dec 31, 2007 | Toshiba 55H70 55" Rear Projection...
Nokia C5 Cell Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
