Question about Canon Rebel XT / EOS 350D Digital Camera
Our camera is not responding when we depress the button to take p
The screen reads: AWB It is set on the green square.
Numbers flash on the screen 80 6.3, for example.
We can eventually get the camera to take the picture, but we keep missing the moment! Our yearbook staff relies on this camera for all our action shots in basketball, etc. Any ideas of what to look for and how to fix it?
Be sure you don't have the automatic timer on.
Posted on Jan 20, 2009
My hp photosmart c200 camera flashes red/green light when depressing shutter button.
Some Cameras flash Red or Green (ie) Red Over Exposed. Green Exposure Set OK. Check Camera Manual to see if you have information on this..
Nov 04, 2017 | HP Cameras
Green pictures
Assuming the camera is not faulty the most frequent reason for a green tint is the selection of the wrong white balance in the camera menu. The menu will contain "AWB", "daylight", sometimes represented by a stylised sun logo and indoor. If you use "daylight" for indoor photos the pictures will have a green cast. Select "AWB" for generally acceptable results. If the pictures have a green cast on outdoor pictures you have a problem
Dec 14, 2013 | Kodak EasyShare CX6200 Digital Camera
Samsung S760 digital camera.Lense does not not retract and there is no display on screen.Camera does not respond when any function button is pushed..Installed new batteries.Green indicator flashes when...
You may have gotten a light debris in the lens. Just the littlest amount will cause the lens to jam. Try a can of compressed air and blowing it out.
Jul 23, 2010 | Samsung S760 Digital Camera
My son has a Fujifilm S1000fd and when I get the pictures printed, there is a yellow hue in the photo, how can I fix it?
Color setting on the camera. Is it set to Auto White Balance (AWB)? Daylight? Fluorescent Lights? Flash? Cloudy Day? It's best to set it on AWB.
Sep 07, 2009 | Fuji FinePix S1000FD Digital Camera
Unsteady White balance
You must switch to preset, push the awb button on the front to switch from auto white balance indoor to auto white balance sunlight (3200k to 5600k). This will automatically balance the camera to the approximate settings needed. For fine tuning the white balance.....
If you want to set the A and B buttons, first switch to A, then hit the Auto button by the user 1,2 3 button until you are off of auto total white auto focus auto iris mode AWB A ch will show in the viewer hit the Auto again and ATW shows, meaning Auto total white is on, and you will not have control over the white balance, it will continue to float and try to automatically balance in the middle of your footage. Once you are on AWB A ch from hitting the AUTO button, then point the camera at the white you are balancing to (of course put the white under the lighting you want to balance to) push the AWB button on the front of the camera and hold it in until the camera goes through the white balance mode and the black balance mode,...the camera will go dark while this is being done but an OK with the correct color temperature will show briefly on the screen when it is done and you can release the AWB button. Now you have set the A button to the white balance for the current lighting.
If you are going to be switching between indoor and outdoor, do the same for the B button above and set it's white balance to the exterior light color temp. that way you can just switch between A and B when you are moving fast between interior and exterior shots and have the correct color temp.
You could always leave the switch on preset, and hit the AWB button on the front to switch from 3200 to 5600, but remember not all light is either 3200 or 5600, that is why we use the A and B settings and get the White balance for the exact color temp of the space being shot in.
Jul 25, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
SD550 camera not focusing correctly. Green focus square sometimes shows up, sometimes not, either way, it's not clear even on the digital screen prior to taking the shot. Camera does make a slight click...
to make the green square show up just press the shutter button until half (this is called the half press) when the green square shows up then it means that the camera has focused already, if not repeat the process til green square comes out you can press the shutter button fully to take picture when you see the green square...
Jul 06, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Flash fails to function.
Can't help on the flash problem. I have same problem and am loking for he solution also, but I can help o the "AWB" issue. AWB stands for Automatic White Balance. You can change in the "Menu" - "White Balance" function.
Feb 14, 2007 | DXG Technology DXG-305V Digital Camera
Cannot get clear close-ups
Recommend not using flash. The first thing is that your subject should be well lit. Try placing it on a lighter background with good lighting around it. Also recommend using a tripod to keep the camera steady, and setting and using the camera's timer to take the photo (this also helps keep the camera steady). The closest auto-focused macro shot that the S200 takes is around 1 foot from the subject. Depress the shutter button halfway to verify that the subject is in focus (one of the three squares on the LCD should turn green on the subject). Next depress the shutter button all the way to take the photo.
Jan 24, 2007 | Canon PowerShot S200 / IXUS 178 Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
