Question about GE JGBP28 Gas Kitchen Range
I have a JGBP28. The igniter was replaced by landlord - I wasn't here. I believe the original igniter was round. It was replaced with flat. Now, I get a glow, the gas comes, and the over fills with gas until there is a whoosh and mini explosion - unless I open the door early and create a backdraft to cause it to light. Both dangerous. Please tell me the igniter this model takes.
I have a lofra cooker mod number mnx66gg1 and i'm trying to get a new door seal for it .
Posted on Jan 13, 2009
Kitchen aid convection range bake igniter stays on
Pull the igniter out and see if there is a short to ground on the wire. If none is found, replace the igniter. Here is the part to order.
Jan 20, 2013 | GE JGBP28 Gas Kitchen Range
Just bought this car I can't open the trunk with ignition key
It either has had the trunk replaced and the old cylinder wasn't installed, or the key you're using is the valet key. See if you can lock/unlock the glovebox. If you can't you're using the valet key. If you can, your trunk lock cylinder is not original.
Oct 01, 2010 | 1997 Audi A4
GE JGBP28 kitchen range
The problem is commonly caused by a weak or failed oven igniter. Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
If only one oven feature fails to work, but the surface igniters still operate, your problrem is not a gas related as both the surface and oven are fed from the same source. Each oven manifold has a separate igniter, so it is most likely a single igniter problem.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number for the model you have listed is WB2X9154.
If you have any qiuestions please post back and let me know. I hope this helps you.
Mar 29, 2010 | GE JGBP28 Gas Kitchen Range
My gas range's oven piezo-electric igniter is not working.
it must be a problem of spark distribution try to remove the spark plug from your piezo electric igniter and clean it throughly it must work otherwise it will have to be replaced
Feb 25, 2010 | GE JGBP28 Gas Kitchen Range
Hello - I ran out of propane - How do I light the ignition?
Your range is electric ignition and should not require any relighting. There may be air in the line and can be purged at the cook top burners. Just turn the burner knob on until it starts clicking and let it click until the burner ignites. The oven and broiler will then light normally.
Feb 05, 2010 | GE JGBP28 Gas Kitchen Range
Two of the burners on the left side doesn't light.
If you small gas, then there should be gas to burners, If you are hearing a clicking, but doesn't light, then your igniter may be corroded or faulty all to gether. You can get parts and manual at repairclinic.com
Oct 22, 2009 | GE JGBP28 Gas Kitchen Range
Oven won't light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Sep 24, 2009 | GE JGBP28 Gas Kitchen Range
GE XL44 oven will not work.
replace the [Glow light] the ignitor same thing, you see the ignitor most be super hot to open the safety valve.I have fix that problem many times before, very comment problem.
Nov 12, 2008 | GE JGBP28 Gas Kitchen Range
Cooktop igniters
You need to replace your "spark module" because it shorted our most likely because it got wet.
Here is a good website to get the part from http://www.partselect.com/
Jun 24, 2008 | GE JGBP28 Gas Kitchen Range
GE JGBP28 Gas Kitchen Range Logo
107 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
