Question about John Deere Garden
John Deere o/f 1445 stalling after one hour and not restarting for quite some time. Have checked fuel cap, all filters replaced, radiator clean out back and front, checked fuel for debris. Still sta
Sometimes when l feel that it is going to stall l cut off the blades and engine continues but only for a short time and then stalls again. I have sent machine to JD mechanic and checks done of previously mentioned items but machine stalled when driven on return
5 Suggested Answers
  • 77 Answers
SOURCE: I have a John Deere/Scotts/Home Depot 20 hp
The easiest way is to not remove the tank. Buy a can of chem tool the liquid,not spray.Drain gas out of tank,pour can in tank,let sit for 15minutes,then drain,should clean it out good.
Posted on Aug 10, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere L118 stalls after it runs
2 problems are common with this machine.One is the earlier machines had bad placement of the fuel line at the tank causing it to get pinched off and restrict fuel flow.It may get pinched at the very top of tank where line starts or between very rear of tank and frame.2nd problem is with the decompression setting of the valves causing engine to have too much compression at start up.Set your valves when piston is a 1/4 inch past top-dead-center.Set your intakes at .004.
Posted on Nov 14, 2009
SOURCE: mower stalls out after about an hour of run time
My Husqy was doing the same thing and had it into two shops and they all thought I was on crack as they never got it to die. I happened to be talking to a customer of mine who used to do small engine repair and he said replace the gas cap. Apparently they are vented and sometimes those vents get clogged. As you mow it sucks gas into the mower and the tank compresses because it can't get air. Eventually the compression is stronger than the suction to the engine and voila, no gas and you die. As you let it sit, the tank slowly pulls air back into it going back to it's original size and you can start it again. Quick fix if you can't find a cap is when it dies take the cap off and let it expand, put the cap back on and start her up.
Posted on Aug 08, 2010
  • 884 Answers
SOURCE: John Deere X300 stalls after running for 1 hour
Diesel filter clogging up, may have water in it
Posted on May 15, 2012
I have a john deere 425 20 hp OHV K series liquid cooled. After about and hour or so of run it overheats and stop. I put a new air filter on it. that didn't help.
check fluid level in the cooler / radiator that its clean 'air can flow through ' air filter is fuel and carb not cooling system --
Nov 18, 2016 | John Deere Garden
Runs for 10 min and stalls.
check your vent hole on fuel cap,or just loosing the gas cap so it can get air if this helps than you know it is the vent.
Aug 12, 2015 | John Deere Riding Lawn Mower. EZtrak Z225...
Search Fixya...john deere 1742 stalls
If your tank had black stuff in bottom check fitting for line going in fuel tank take piece of fuel line look if inside is swelling close and soft ethanol fuel is ******* rubber replace lines don't cost much
Jul 03, 2013 | Garden
John Deere x300 runs for about 30 minutes then stalls. There is no gas in the filter.
Check your fuel cap to make sure it is venting properly. If a vacuum is being created, and no air is able to get into the fuel tank, it will prevent the fuel from reaching the carburetor.
Oct 17, 2012 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
475x runs out of gas during normal ops. Leave key
the gas cap quit venting the tank...it's causing a vacuum that the pump can't draw fuel against...to check, loosen the cap and cut some grass...if it works, clean out the hole in the top of the cap...if not replace the pump..
Apr 18, 2010 | Garden
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Garden Logo
226 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
