Question about Konica Minolta bizhub 420
Error 2803 konica minolta 500 - Konica Minolta bizhub 420
    President:
  • Konica Minolta Expert
  • 347 Answers
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
Posted on Feb 15, 2013
How can i fix rror code c-2803 on b361
Sir/Mam,
You recently replace the drum and the developer??? if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN TCR/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the TCR is run. Or you will start all over again with new developer and a new drum.
Sep 20, 2016 | Konica Minolta BizHub 360 361 420 421 500...
How to reset konica 361 error code c-2803
Your developer needs to be replaced. Along with clearing certain counter and running certain procedures after developer is replaced recommended having a konicaminolta tech do that. quite a lot to do.
Feb 27, 2015 | Konica Minolta Office Equipment & Supplies
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
Error code c2703 konica minolta c6500 will not start
Please chalk The Developer tank there nite be short in developer
Dec 29, 2012 | Konica Minolta Bizhub 500...
In biz hub 500 the machine is showing error code c2803 what is this
My machine Bizhub 500 Sows a code 2803.Find its solution please help me.
Jul 12, 2012 | Konica Minolta Office Equipment & Supplies
Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
May 06, 2009 | Konica Minolta Office Equipment & Supplies
ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Feb 19, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 420 Logo
524 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
