Question about Kodak EasyShare C143 Digital Camera
IT COLOR RED
ALL PICTURE CAME TO COLOR READ, HOW CAN I RE FORMAT TO FACTORY SETTING
  • Kodak Master
  • 17,130 Answers
Possible that the CCD is failing and could be an indicator , if so you will need to replace the same.
Posted on Dec 11, 2012
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
Red tint on screen
u shoud reset your setting try to on
Jul 27, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
I own a 3 year old Panasonic TH-50px77u. The picture has changed and no longer shows and red color in the picture. This seemed to change when I plugged in an XBOX video game 3 night s ago.
If I understand this correctly, since you connected one of the HDMI inputs to an X-box, you do not see any red in any picture from any source, not even the SD Photo display input. White areas in the picture are cyan colored; other areas are various shades of blue-green. Red areas are black. This is the worst case; it is not clear from your description whether this is what you see or if the red areas are just not red enough.
Try going to the Picture menu and changing Picture Mode to "Normal", and Normal to "set". Turn Color mgmt. off. Refer to pages 26-27 of your owner's manual (download here). If this doesn't help, try selecting different Color temp settings. Make a note of which combinations of settings are giving you good results and which are giving you poor results.
If you cannot get close to factory default color, download the service manual and post back so we can take a look at the numbers in the video processor's EEPROM (data memory). We can continue diagnostics from that point if necessary. You may want to compare the EEPROM numbers for the settings that give bad results with the nominal values given in the service manual - if one of the numbers for red is way off, that could be the problem. Please post back before trying to change any numbers in the EEPROM - we don't want to make a bigger mess, and it would be a good idea to figure out what is going on first.
Jan 02, 2011 | Panasonic Televison & Video
Something has happened to the color on my tv. it's lost the reds in the picture. face color is good. pinks, blues and greens are ok. i've unplugged and re-started. how do you go back to default...
Look for color temperature settings under the menu and video settings. If there is an overall factory reset or restore to factory settings, try that as a last resort.
Mar 06, 2018 | Tatung P42BSKH Television
My samsung BL103 was taking black and white pictures. I was trying to get it back to color. I went to settings hit format, said yes or no? I hit yes and now have no pictures on my memery card. Can those...
Format completely erase the memory card with no hope of recovery. You need to dust off your manual and read it to find the correct setting for color pics.
Oct 26, 2010 | Samsung BL103 Digital Camera
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
Jan 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Color difficulties
Have you tried using the video inputs, Is it able to show red then ?
If not & you have reset the factory settings the prisim or mirror's may have gotten out of alignment in shipping, Or it may have a bad lcd panel or the red lcd may have a bad connection or driver circuit.
Feb 13, 2008 | Office Equipment & Supplies
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Kodak EasyShare C143 Digital Camera Logo
21 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
