Question about Hotpoint RVM1435 Microwave Oven
Won't heat, works otherwise
I recently got this oven from a contractor who replaced it for a customer. They claim it worked fine until there were some bad storms in the area one night. Now when you turn it on, everything seems to work fine. You can hear the distinctive sound of the magnetron's deep hum, and when running it on lower power settings, you can hear the magnetron turning on and off as it should. Trouble is, it doesn't heat anything. My question: How do I know for sure if its the magnetron? Could it be the HV capacitor instead? What else could it be if not those? Thank you
  • Justin Anderson Jun 15, 2007
    ...Ok so I replaced the magnetron, and it still acts exactly the same. Hums like it's working, but no heat.....wtf?
    (banging my head against the wall....)
  • Hotpoint Master
  • 9,098 Answers
It's likely to be the magnetron or a bad connection on the FA terminal of the magnetron, but it may be a bad connection or relay on the control board. This is a page showing how a microwave oven works. A detailed, illustrated explanation. http://www.gallawa.com/microtech/how_work.html If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Also, this model may have a "mini-manual" / tech sheet inside which is very helpful in troubleshooting.
Posted on Jun 12, 2007
Can two separate convection units (microwave and oven) be combined/joined into one cord and plugged into one outlet and BOTH work efficiently? The contractors I hired combined all wires to both unit
You need to have the contractors return and troubleshoot the problem free since they told you they both worked when you purchased them. There's an implied warranty here. The two ovens should have been tested before the contractor left your house to prove they both worked together.
Dec 21, 2014 | KitchenAid Microwave Ovens
Baumatic oven ba896ss
there is a good chance the electric surge has blown the pcb
Mar 26, 2014 | Microwave Ovens
Yesterday I started heating food in the microwave and immediately heard a loud popping noise. I stopped it to see if there was metal inside. which of course there wasn't any. It now won't heat and the...
There is an internal fuse but if you still have power on the display then likely the main transformer has failed and the cost to repair will likely exceed a replacement.
Aug 12, 2017 | Whirlpool GH7155XHS Microwave Oven
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
I auto cleaned my oven the other day. I wiped it out with a damp cloth and later on that night went to turn it on and it would not heat up. The power turns on and the display seems to work normal and the...
Hi, Look at the home breaker box or fuse box to check for a tripped breaker or blown fuse. If your oven is not heating because there is no power, you may need to replace a fuse or reset a breaker. Also check the power outlet to confirm that the oven is plugged into the outlet securely.
Press the "START/ENTER" button to get the oven to heat after selecting your temperature, if you cannot get it to heat. If you do not press this button within five minutes of setting the temperature, the oven heating cycle will automatically be canceled and the oven control panel will return to displaying the sign.
Calibrate the temperature setting on the oven if it is not heating at a temperature that you like. Do this by holding down the "BAKE" button until the current calibration setting appears, which will be a temperature followed by "CAL." Use the up and down arrow button to increase the temperature and press the "START/ENTER" button once you are done. You can increase in five degree increments up to an additional 35 degrees.
Call the Whirlpool customer interaction center at 800-253-1301 if your troubleshooting fails to fix your heating problem. The customer service representative can give you contact details for a local service technician so that you can have the oven looked at by a professional.
Hope it helped
Aug 25, 2011 | Microwave Ovens
My GE gas oven won't heat up. The stove top and broiler work fine but when I turn the oven on, nothing.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 03, 2011 | Microwave Ovens
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Bottom of door inside badly rusted - oven works fine
Yes you can paint it.. Begin by removing the rust with either a wire brush or a thick paste product called naval jelly. Then prime the area and finally paint it with appliance paint, abailable in a spray can at most hardware stores in the color of your appliance.
May 26, 2009 | General Electric Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
112 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
