I want to take out spinning bit in middle - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Remove the spindle and bearing assembly,Check on this link:
replacement of bearings.
Posted on Dec 11, 2012
What are the small white bits in drum after final rinse
I"m not sure, but do they look like plastic. Does the auger in the middle spin, both the top and bottom part. If not, the little dog used to get the machine to agitate can be broken, and that is what you see. if so it is a two dollar fix. can order them online.
Sep 22, 2012 | Indesit Washing Machines
The washer will drain but not completely ..leaves a litlle bit of water in machine
Make sure the spin is working. If its not working you wouldn't know it since it spins during the middle and end of cycle.
If not check lid switch
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Frigidaire FEX831CS Top Load Stacked...
LDF7932ST LG dishwasher top and bottom arms not turning. Diagnostic test mode "power+spray+ rinse" does not work.
I put a new lower spray arm and very little water comes out of it. There is quite a bit of water that comes out of the middle and top. The top does not spin but has quite a bit of water and the middle spins really good.
Jun 25, 2011 | LG 24 in. LDF 7811 Stainless Steel...
Sud code in the middle of the cycle
you're using to much detergent,the machine can't pump out suds,it will start to fill and drain to get the soap out.take out the clothes,run it and after a bit hit the drain spin and see if it stops.using to much detergent is the number one killer of front load washers,the extra detergent eats at the spider gear and when this happens it's time for a new washer,you'll know when it breaks,when it goes into the spin cycle it will bang all around loudly,you should only be putting in 1/4 of a cup of H.E. detergent
Mar 05, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Machine stops in the middle of the cycle. I had only a robe and pair of pajamas in the tub and water level set at medium. I moved it to "spin cycle" to get the water out of clothes, but nothing...
Same problem as yours. The GE repair man is at our house right now for this problem. It's the motor, and the "special motor and clutch package" has to be specially ordered.
Jan 04, 2011 | GE Profile WPRE8100G
Was using with a spsde bi and hit a nail. Now
You may have inadvertently hit the hammer/drill switch and it is floating the middle between functions. This selector switch has a symbol showing a drill bit on one side and a symbol of the hammer on the other. Engage the switch bacK into the drill position
Jun 08, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Noisier than when it's new (Atlantis washer machine)
If a bearing runs freely and does not stop within a few seconds, the bearing is dry and needs to be replaced. A bearing with the proper amount of grease will not spin very long due to resistance from the grease. A bearing that makes noise when spinning needs to be replaced. This means that the surface where the needles/balls run on is pitted and the bearing will self destruct.
The name of the bearing is a "thrust bearing".
Sep 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Troy bilt mowers rope will only come out a little bit. what kind of tool do i need to take the rope cover off.flat screw with hole in middle?
I know what you are talking about. but i don't know what the tool is called, but i have an answer to your second problem(rope coming out a little bit). the problem is that there is a lot of junk stuck in the place where it spins. all you have to do is soak it in mineral spirits over night, and in the morning turn it in and out till it works perfect. I worked on one of these last night
Apr 28, 2009 | Troy-Bilt Chipper Shredder
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
