Question about Electronics - Others
Nokia n79 doesn't support micro sandisk ho i can fix it
  • 2,878 Answers
Reformat in the Nokia.
Posted on Dec 11, 2012
3 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
Posted on Jan 26, 2010
abdulkarimap
  • 149 Answers
SOURCE: My Sandisk 'Wake up your phone' adapter
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Posted on Oct 12, 2011
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My memory card is automatically password protected i don't know ho w to unlock it. i'm using nokia 3109 classic, the memory card is accessable only in this device asking for password, it is not...
The best solution for your problem is to recover your files using recovery software and after recovery, format the memory card. After formatting your memory, plug your memory card to sd adapter and check it still the same or the password is gone. If the password is still there, in that case you have to buy a new memory card, hence you already recover your files so much better to start saving data with a new memory card. Have a nice day!
Jun 09, 2011 | SanDisk 2GB microSD Memory Card
My nokia n79 shows general system error when i go to delete photos/videos. have'nt delete the gallaries photos & videos
please sale your Nokia N79.Because comapany has no solution for it. My Nokia N79 had 4 time swapped by company because of this problem.
Aug 15, 2010 | Nokia N79 Cellular Phone
I have forgetten the security code
i have transcend micro sd 1 gb card but i have forgot password
Mar 02, 2010 | Nokia N79 Cellular Phone
I forget my nokia n79 security code
hi, Dear u can unlock this phone with BB5 master code generetor.. find in on google
Dec 04, 2009 | Nokia N79 Cellular Phone
I have forget my lock code of nokia n79 how could i change it nw
please visit to service center if in warrenty and ask them to fix it...or reinstall the software of phone from nokia.com
May 26, 2009 | Nokia N79 Cellular Phone
Open Questions:
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
