Question about Mitsubishi WD-52528 52" Television
I cant have audio when a use the dvi conection :/
Already got the RCA connected
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Its a early set of this series, If set works from RCA style what are you trying the DVI for? A bit of an explanation of what you hope to gain and what the set is doing or NOT doing would help to assist you.
Posted on Dec 11, 2012
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
Where does the HDMI cable plug into for a Blue ray player?
i have the same tv. there is only a dvi input with separate audio inputs.you will need a dvi to hdmi adaptor to connect for hi def.hdmi is video and audio while dvi is only video.you still get the picture quality,but have to run audio rca cables also.
Jan 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I connect my Toshiba LCD television to my computer using hdmi
HDMI carries both "audio" and "video" signals, while DVI carries only "video" signals.
Does your computer have a HDMI-output port, or separate DVI-video and stereo-audio ports?
If the former, then one HMDI-to-HDMI cable will make all the necessary conections.
If the latter, you'll need a cable to connect "line-out" from your computer's sound-card to the left/right RCA-jacks stereo-inputs, and you'll need a DVI-to-DVI cable to transmit the "video" signals.
Oct 22, 2010 | Toshiba Computers & Internet
This may be an impossible problem to solve..we just got a Hitachi 51m200 rear projection tv. it does not have an hdmi slot although the tv says it is dvi-hdtv and our cable box is hdmi output. so if i get...
It isn't impossible at all. You may need a sound bar if you don't already have a Bose surround sound system or a boom box or something else you can use without purchasing anything. On the hdmi/dvi televisions and cable boxes of the recent past there would always be an accompanying white and red composite/RCA slot (output on the cable box, input on the television) to accommodate this. You would simply connect the hdmi to dvi cable from the television to the cable box and then the red and white audio cable. If your television and cable box does not have the red and white composite/RCA audio input and output you will need to connect the cable box to an external audio source. How to do it and what to connect it to depends on what audio output that is on the cable box (usually is on the back of it). You might need a fiber optic cable and a sound bar with a digital audio input if you have a newer cable box.
Sep 28, 2010 | Televison & Video
Ive recently bought a 1080i samsung tv and was wondering will is there any way to connect it to a hdmi cable so i can play my ps3 in better quality?.
IF YOU HAVE A DVI CONECTER A BIG WHITE PLUG WITH MANY CONNECTERS YOU CAN BUY A HDMI -DVI ADAPTER BESIDE THE DVI CONNECTER YOU WILL HAVE INDICATION FOR DVI AUDIO YOU MUST PASS TWO AUDIO CABLES FOR SOUND
Jun 03, 2010 | Samsung HC-P4241W 42" Rear Projection...
I have an RCA D52W20 that I connected to my PS3 with an HDMI/DVI Cable. The display is fine in 480i. However, No sound is coming from the TV.
This is normal my friend. A dvi port can't use audio even if it is using a hdmi cable. A easy fix is to connect your A/V cable into your ps3 and connect the red and white cables next to your dvi cable or connect it to your stereo. After that go into your setting, go to audio setting, click on audio output, and select A/V cable. it should work after that.
Mar 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Cant get audio from my hdmi rca sockets
The problem is that you are trying to use too many connections at once and it is confusing the system. HDMI connection covers both sound, and video. So, no other connection is needed. Try using only HDMI. If that does not work. Use DVI for video and RCA for sound. Also you may need to change the settings in your PC so that it recognises that it is connected to HDMI, or whichever connection you decide to use.
Apr 16, 2009 | Samsung LN-T3253H 32 in. LCD Television
I want to hook up external speakers to my Acer H213H for when my PS3 is hooked up to it.
What method are you using to connect to the monitor?
If you are using the HDMI -> DVI adapter it does not support sound. HDMI does, but DVI does not.
If that's the way you are set up then all you need to do is use the HDMI -> DVI adapter for your video and use the regular RCA connections for audio.
You can set the video and audio settings in the PS3 with the "Display Settings" and "Sounds Settings"
That way you just use the red and white RCA ends to connect to a speaker system, the yellow won't be in use at all.
Dec 10, 2008 | Acer Computers & Internet
Mitsubishi WD-52528 52" Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
