Defy washing machine front loader door doesnt activate wash cycle
The door doesnt seem to activate the wash cycle.
  • Jessica Smit Dec 19, 2012
    a technician confirmed your suggestion. I have replaced the door switch and the retaining wire (OMG!) but still no wash?
  • Washing Mach... Master
  • 17,130 Answers
Possible that the door switch is not activating as it can be faulty. All you need is to remove the switch which is seen at the point of the lock and check using a continuity tester for the connection. if not replace. If the switch is OK then it can be fault in the controller unit.
Posted on Dec 11, 2012
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
SOURCE: FRONT LOADER DOOR LOCK WONT OPEN OR JAMMED
On a Bosch wfmc3200uc there is a green plastic string, similar to fishing line, located behind the round panel on the front of the machine. It is attached to the top right of the round black piece. Just give a slight tug this will release the lock.
Posted on Oct 21, 2008
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
go to macspares.co.za
They have couple of diagrams
Posted on Mar 29, 2010
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Door won't close on J845 front loader
Replace door lock. Also check tightness of hinge v
Nov 15, 2017 | Washing Machines
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
My washing machine door is not opening at the end of a cycle. I put it onto another and it still won't at the end of that one. I've turned it off as well for 10 mins or so, and still nothing. Please help!
you didn't state whether it's a top or front loader. either way, there's a switch activated when the door is closed and washer is in cycle mode- so you can't open the door when a. the front loader has water in it, or b. the top loader is in agitate, or spin cycle. if top loader- there's a tab on the end opposite the hinge side that activates a switch that latches the cover closed when in 'dangerous' cycles (don't want to get your hand caught in the spin cycle!!). either a loose wire or a failed switch! prob. need to gently pop the top (should hinge back) to access the switch. UNPLUG THE WASHER!! if a a loose wire, re-attach-if not, replace switch! easy! good luck!
Apr 17, 2010 | Washing Machines
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
My front loader is driving me nuts. everytime I
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Feb 05, 2010 | Zanussi FJS1225W Front Load Washer
I can't open the door of my washing machine it is a front loader lg intellowasher 7 kg wd8013c please help asap
FOR ANY REASON THE WASHER MACHINE DIDNT FINISH ITS CYCLE!!! AND IT IS A SAFETY THAT IF DOESNT FINISH ITS CYCLE THE DOOR WONT OPEN!!!!
I HAD ONE LIKE THAT AND I BROKE IT APART!! AND I SAW THE WATER PUMP WAS THE PROBLEM SO I CHANGED IT AND PUT IT BACK TOGETHER AND LET FINISH ITS CYCLE AND OPEN THE DOOR!!! AND STILLS RUNNING!!!
Oct 05, 2009 | Washing Machines
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
