Question about Kenmore 49972 Front Load Washer
Bottom leaks and the drum seems to rattle/knock when spinning. Sometimes there is a little water left in the bottom after removing clothes.
About 4 years old - Light usage
  • Kenmore Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Dec 11, 2012
SOURCE: washing machine wont spin, water still left in drum
machine wont spin just turns back and forth
Posted on Jun 01, 2009
  • 72 Answers
SOURCE: no water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Posted on Jun 07, 2009
grandadfixer
  • 99 Answers
SOURCE: Washing machine does not spin and holds water after door is open
Sounds like pump blocked check.
Posted on Jun 11, 2009
Maytag317
  • 1136 Answers
SOURCE: washer is leaking from the bottom.
Hi, Was the noise a whining sound? It is possible something was in the pump amd it wore a hole in the pump. After the washer shuts off, tip the washer against the wall and look at the pump located behind the front panel in the center. It is attached to the motor. Check and see if it is dripping water.
Just an idia to start with.
Please let me know what you find and if I can assist you further.
Vic
Posted on Jun 28, 2009
hiltonjug
  • 612 Answers
SOURCE: Wet Clothes and some sandy crud left at spin cycle end
Make sure you plugged the wires back in that you unplugged to take the case off. The plug located under the panel. This is you lid switch and if it's unplugged it will not spin clothes out. If it is plugged in, you might want to go back and take the pump off. Once you have, check inside the drain tube that connects from the pump to the tub. Make sure there is nothing inside it. Sometimes lint will build up inside it, clogging it.
Please rate solution
Posted on Oct 02, 2009
NO ERROR CODE BUT WILL NOT SPIN WITH USUAL SPEED NOR SPIN OUT WATER-CLOTHES ARE WET, DRIPPING WET OFTEN. WHAT IS CAUSE OR BROKEN?
Well it could be clogged. I that case machine should be open at the bottom and take down the hose that connects to drum.
Here there are multiple problems it is probably electronics. Unless you find some cheap replacement that machine is gone.
Apr 14, 2016 | Speed Washing Machines
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking from bottom on spin. also makes rattling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 10, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Maytag washer
Many of the maytag toploaders have a rubber fill hose at the top of the outer drum.
Sometimes if the machine is fully loaded (or overloaded), during the spin cycle if clothes are above the top of the drum they can actually knock the rubber flange of the hose out of the drum. Then when the machine fills with water, it will dump it down the outside of the tub and it will appear that the water is leaking from the top and side of the drum... Fix it by snapping the fill hose flange back into the hole in the top part of the drum... let me know how you do or need more help...
Mar 23, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Leaking whirlpool duet washer front load
remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine Drum rattles
It is probably between the clothes tub and the outer tub. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Aug 03, 2006 | AEG Lavamat W1050 Front Load Washer
Washer leaking water from bottom
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Jul 30, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 49972 Front Load Washer Logo
44 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
