How to check/connect - Office Equipment & Supplies
  • 7,627 Answers
Any printer do, or do you need a specific one?
Posted on Dec 11, 2012
Last green light flashes
1 Flash The batteries need charging. Check the battery connections. If the battery There is a bad connection to the batteries. connections are good, then try charging the batteries. 2 Flashes There is a bad connection on the left motor. Check the left motor connections and wiring harnesses. 3 Flashes The left motor has a short to a battery Contact your authorized Pride Provider. connection. 4 Flashes There is a bad connection on the right Check the right motor connections and wiring motor. harnesses. 5 Flashes The right motor has a short to a battery Contact your authorized Pride Provider. connection. Rippling LEDs The charge inhibit has been activated. Make sure that the battery charger is not connected to the power base. 7 Flashes There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. 8 Flashes There is a control system fault. Check power module and joystick module connections and wiring. 9 Flashes The park brakes have a bad connection. Check the left and right motor connections and wiring. Check to make sure that the power chair is not in freewheel mode. 10 Flashes An excessive voltage has been applied to Check the battery connections. the control system.
or go here and find yours,if you would of given the info we need,i would of diagnosed it for you,but,you didnt Pride Mobility Products Corp Basic Troubleshooting Instructions
Apr 20, 2015 | Health & Beauty
Tip
Powerchair flash codes (Applies to most powerchairs)
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace
10 and 11 are unusual and will not be seen if at all
on Mar 06, 2011 | Health & Beauty
Tip
How to troubleshoot water leaks
Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.
Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Check the lid seal. If faulty, replace with a new gasket.
- Check the hoses at faucet connections. Tighten connections or replace hoses.
- Check the hoses at water valve connections. Tighten connections or replace hoses.
- Check the drain hoses. Tighten connections or replace hoses.
- Check the inlet nozzles. Tighten connections or replace nozzles.
- Check the splash guard. Tighten connections or replace.
- Check any plastic valve. Tighten connections or replace.
- Check the outlet hose to drain. Tighten connections or replace hose.
- Check the water pump, using the procedures that follow.
on Jan 16, 2010 | Washing Machines
I can not sign in
INSTALL VERSION 10.0.....,THERE ARE PROBLEMS WITH YAHOO MESS 11.
Jul 14, 2013 | Yahoo Messenger
Cant sign into yahoo messenger. Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw]...
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [PASSED]
[VIP Raw] PASSED *** 98.136.48.85 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0001' ***
Aug 10, 2010 | Yahoo Messenger
Old admiral clothes washer leaks at front
Troubleshooting Water Leaks
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Step 9: Check the water pump, using the procedures that follow.
Aug 25, 2009 | Maytag PAV2300 Top Load Washer
Wireless connection Dell Latitude E6400
Look for a switch that turns on the wireless device. Also check in the connection manager if the device is active and the wireless adapter is within range.
Aug 14, 2009 | Dell Latitude E6400 Notebook
18 people viewed this question
k24674
jasbo
jasbo
