Question about Samsung SMH9187 Microwave Oven
Smh9187w vent fan popping noise
When I turn on the vent fan on my smh9187w I hear a popping noise and the fan just buzzes without any airflow, except on settings 4 and 5. I took off the grill and looked inside while turning on the fan and see that there is some sort of arcing happening in the back near the top. I'll assume this isn't normal. This is a continuation of a previous post where I suspected the PCB, but now I'm thinking it's more likely the vent motor. The unit vents out the back. I had just replaced the control panel prior to this happening, and I can't figure out how these could be related. I'm starting to think they're coincidental. Microwave heats fine; all lights work. Do I need a new motor, or should I disassemble and find where the arc is happening? Thanks!
  • Samsung Master
  • 9,098 Answers
There are no bulletins covering a recurring issue with the exhaust fan on this model, so I would suspect the failing motor, an obstruction in the blades, a loose blade assembly, or a damaged wire arcing to the frame.
It will take some visual inspection with the oven removed from the wall (see your installation instructions) and the cover removed.
The service manuals for the variants are here:
http://www.microwavedisplay.com/smh7185_smh9187w_xaa_sm.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v1.pdf
http://www.microwavedisplay.com/smh7185_smh9187w_xac_v2.pdf
http://www.microwavedisplay.com/smh9187b_smh9187w_smh9187b_xaa_sm.pdf
You can order Samsung parts from the Pros here or from Encompass here.
Posted on Dec 11, 2012
Vent fan will not turn on.Display keeps showing vent fan off
Did this occur after a failure of your cooktop lights?
Or is there is buzzing noise present when the oven is not operating, or when the door is opened?
If so, then the problem is on the control panel, which can be repaired economically.
There is a a YouTube video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jan 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
Buzzing sound on all functions, including when light is turned on;fan vent not opening when fan turned on; not heating. is this a short/malfunction of control board?
sounds like a control/display board issue but if you microwave has a noise filter board (fuse is mounted on it) it could be that
Feb 04, 2010 | GE JVM1860 Microwave Oven
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 Buzzing
Chances are this is a problem on the control panel. We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Jul 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave problem
Is it possible that grease or moisture got into the controls? This can happen when cleaners are sprayed directly on the keypad; when boiling is done on the stovetop without the hood vent fan being on; when the hood vent filter is clogged; or due to restricted airflow in exhaust. The best way to check the airflow is to turn the hood vent fan on and use your hand to feel at the exhaust outlet outside the home. Moisture can cause the keypad or control board to short to some degreee, and produce odd results. It may clear up, but sometimes it requires that the keypad be replaced or that the board be professionaly cleaned. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We also repair microwave control boards for customers nationwide for $39.95. Feel free to contact me there directly if you have further questions.
Jun 16, 2007 | Samsung SMH7174BC Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
Samsung SMH9187 Microwave Oven Logo
73 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
