Question about HP LaserJet 3055 All-In-One Printer
49 error when i save date or time i orcured this error
  • 826 Answers
49 error means firmware error..
solution:
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error.
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again.
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Dec 11, 2012
P4P800-VM BIOS was Upgrade but BIOS Date & Time can't save from BIOS
If your cmos battery is new and the date and time not change. Try the following.
1. Clean the cmos battery terminals.
2. Check your mother board if there is bulges capacitor.
3. Check the memory you have using if in the same voltage requirements.
Hope this will help to you.
Jun 15, 2012 | ASUS P4P800-VM Motherboard
I can't surf gmail.com.there is a certificate error
Certificate errors are typically caused by an incorrect date or time in your operating system's calendar.
To set your Date and Time Properties in Windows, please follow these steps:
  1. Double-click the time in your taskbar to open the Date & Time Properties menu.
  2. From the Date & Time tab, verify that the appropriate month, day, and year are selected.
  3. Click Apply to save any changes you make.
  4. From the Time Zone tab, verify that your time zone is selected. If the time zone in which you are located is not displayed, select your time zone from the drop-down menu.
  5. Verify that the box beside Automatically adjust clock for daylight savings changes is checked.
  6. Click OK.
  7. Close all your browser windows, restart your browser and try logging in again.
Mar 28, 2011 | Google Gmail
Hp laserjet p3005 freezing at times ,at times erroe49.4c02 pops
Hello, 49 errors can indicate a hardware or application error.
The formatters in the P3005 series have been plauged with problems, freezing being one of them.
For more on 49 errors follow the posted link.
Support 49 Errors CLICKHERE
Feb 03, 2011 | HP LaserJet P3005n Printer
I have a Pentax IQZoom 160 and it has error code U3 when I turn it on. The flash and zoom try to deploy several times but only the flash comes out.
If the 'U' disappears when the zoom lever is moved your camera is ready to use. It may be defective if it comes up often.
(IQZoom 160 manual p.49)
Dec 04, 2009 | Pentax IQZoom 160 Date 35mm Point and...
Ibm thinkpad
The 161 CMOS error means the CMOS/BIOS battery is dead/flat and needs to be replaced.
The 163 CMOS error means the Date and Time could not be updated when you change the Date and Time setting. This is caused by the flat CMOS/BIOS battery.
When you replace the battery with a new one, the BIOS will go back to the default settings, go into to BIOS setting (press F2 when you boot up) and change the Date and Time, then save and exit.
Jul 29, 2009 | IBM Computers & Internet
Compaq Presario 1272 save disk error
On the motherboard of all computers is a small battery. It looks like a watch battery. The purpose is to keep a small amount of electricity going to the motherboard so the time and date can stay current. When that battery gets low on power or dies then the time and date is wrong. Its called the CMOS battery and it needs to be replaced and then everything will return back to normal. You can do it yourself if you're confident or take it to computer repair shop.
Don't forget to rate this solution before you log out.
Jan 25, 2009 | Compaq Presario 1200,1600, Series CD...
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Problem with saving time and date
After the warming up machines wants the Date and time.
first you press the stop button then enter 0101 followed by "enter" button. after one mints you machines display shows
"ready 100%"
if you are switch off the machines more than 7 hrs. again ask the date and time , then do the same steps above.
if you wants to enter the correct date and time pls. enter the month as first , then date , then year. suppose you want to enter today's date
like " 06012014"
ok....
May 23, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Error
According to sony that error code is refered to as a time and date storage issue.
Follow the steps below to troubleshoot this issue.
NOTE: It is normal for the camera to loose time and date settings when left uncharged for an extended period of time.
  1. Connect the camera AC adapter, and leave the camera in the charging state (powered off) for 12 hours.
  2. Set the time and date in the camera.
  3. Turn off the camera.
  4. Turn on the camera.
  5. Check to see if the date and time have been saved.
Feb 20, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
HP LaserJet 3055 All-In-One Printer Logo
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
