Question about Dishwashers
My electrolux dishwasher is throwing an E32 error
When I try to start it, it makes a hum sound (almost like a stuck motor) and then stops. If I open the front door, I can freely spin it. I've seen some articles that it might be the pressure sensor, but that's about all I know (I haven't dug in enough to know whether it is or not, or where the pressure sensor is).
  • Official Brand Answer
  • 4,342 Answers
Hello Heber Allred - Are you certain that the error code is E32? This manufacturer does not have an E32 error code for any dishwasher. They do have E02 or E12. Is the hum noise more like a grinding noise? If so, then I recommend contacting a professional to move forward accurately. The unit may be experiencing an issue with a faulty drain motor.
Posted on Dec 13, 2012
  • 1894 Answers
SOURCE: My Frigidaire Dishwasher motor is not spinning rinse cycle
am not sure.. just try this
Check with a multi-meter for 115/220V on motor's tags.
If you don't get this voltage measurement, your problem is not with the motor.
In case you have 115/220V on motor's tags, try first to replace its brushes (2 carbon contacts that transfer the curent to the motor's armature).
try this good luck
Posted on Dec 25, 2007
SOURCE: Candy Dishwasher CS455M
i have just bought a candy dishwasher cs455 and have no manual can you tell me the best wash and what to set it on thanks
Posted on Feb 05, 2008
SOURCE: I have a Frigidaire Ultra
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
SOURCE: GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Posted on Dec 23, 2008
TechBrian
  • 15 Answers
SOURCE: Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Posted on Mar 08, 2009
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
Dishwasher fills with water. then hums but dosen't clean
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
My model number is 70209974. My dishwasher either won't start at all or it starts sounds as though it is filling then stops and make a humming sound but nothing is happening. There is no error code...
Hello
Unplug the appliance and take off the inspection panel below the door.
Check to see if the base has water in it.
When these machines have a leak into the base the circulation pump motor tends to sit in the water (poor design).
If your motor was wet, this would trip the mains.
It may also blow the pcb.
You could be looking at a pcb and motor change to repair your appliance.
It may be worthwhile drying out the motor, a fan heater aimed into the inspection panel (open) would help.
Once dry, try the machine again.
If still no joy, take the door apart and see if there is physical damage to the control board in the door.
Aug 22, 2011 | Belling 24 in. IDW603 Built-in Dishwasher
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Mar 07, 2009 | Dishwashers
Electrolux ESL4114 problem
see other problems listed ,other machines have similar problems one chap suggests that the FLOAT SWITCH is stuck or faulty causing the inlet valve to read as full so continues program...
Oct 30, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Dishwashers Logo
231 people viewed this question
Top Dishwashers Experts
