Question about GE WDSR2080D Top Load Washer
Water fill problem
Water will not shut off when filling, overflows onto the floor. The other wash cycles work properly. I think it may be what is called a pressure switch. If it is this switch, can you tell me where it's located? On the top control panel? Washer is just over a year old and no longer covered. Thank You, Larry
  • Larry Sallee Jun 14, 2007
    Thanks,
    The clear plastic tube to the pressure switch is open. Replaced pressure switch, no change as water continues to flow into tub and overflow without stopping. The other cycles work properly. Machine is just over a year old and out of warranty, so I have to fix it at my expense. Don?t think I?ll buy a GE again.
    Larry Sallee
Did you try replacing the water valve?
Posted on Jun 22, 2007
    President:
  • 1,294 Answers
The pressure switch is close next to the timer switch. There is a thin tube going to the bottom into the outlet pump. Check to see if this tube is free from any blockage, by disconnecting from top and blowing into it. The tube shd be free, and your water will cease to overflow. Refix tube carefully.
Posted on Jun 11, 2007
My Kenmore Washer 110.92597200 will not stop filling which causes water to overflow drum onto floor. It does not seem to respond to Water Level setting.
top loader machines have a small tube running up to the sensor that fills with water and affects the level settings
check that it is not a problem with the inlet solenoid not shutting of the water
call a service technician
Nov 27, 2017 | Kenmore Washing Machines
My washing machine keeps filling with water
If the washer keeps filling up without overflowing onto the floor , then you have the drain hose too deep into the drain and it is siphoning, pull the drain hose back up from being so deep and have it only about 10 inches into the drain, tie it into place with a shoestring or wire tie.
Now if your problem is that the washer is overflowing onto the floor, then there is a clear rubber hose that has been disconnected from the washer, this is the diaphragm hose. Have a technician reattach it. It shuts the water off and starts the machine when its gets enough water, but it wont if the hose is disconnected. Mr Burk
Feb 15, 2015 | Washing Machines
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
Set it going, fills up ok, goes through washing cycle but after spinning and then filling up for next cycle it overflows
Rather hard to understand your problem from the wording in the question but what I understand to be the case is that your tub fills up with water and overflows after the cycle is finished. Perhaps overnight water slowly fills the tub. This is due to the water inlet valve not shutting off all the way. The Inlet valve assembly needs to be replaced.
Apr 27, 2011 | Washing Machines
Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Jul 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Cold Water Solenoid Problem
The fill switch has a diaphragm that could be damaged and not closing properly. I have personally experienced this problem before. The way water could be getting by the switch (even with no power applied) is simply water pressure in the lines. I don't understand why it would work during the spin and rinse cycles, however. If you say it's not a pressure switch problem (level sensor), then I would invest in a new fill valve. I hope this helps.
Jul 08, 2007 | Hotpoint VBXR1070W
Water in bottom of dishwasher
You could have a defective fill valve that is not shutting off properly. Look for a fill inlet opening somewhere on the inside casing of the wash tub. Usually it is on the left hand side of the machine looking in. While the dishwasher is sitting idle, watch the fill valve opening to see if water is leaking in. It could be a minor as just a drip. However, over a period of several hours you could end up with a wash tub full of water. Over a weekend with no one home, it could overflow onto the floor. The valve usually cannot be repaired and would require replacing. Good luck.
Jun 12, 2007 | Bosch 24 in. SGS43C12 Classixx...
GE WDSR2080D Top Load Washer Logo
115 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
