Question about Mr. Coffee 12-Cup Programmable Coffeemaker
Add the water, turn it on, it beeps, but no coffee?
I have used the coffee pot once since I recieved it as a gift for x-mas. Now I put the water in and the grinds but it beeps at me and doesn't even heat the hot plate nor put the water through the filter.
    Problem Solver:
  • 16 Answers
Please check if you have got catlog with you.If you dont have that then i will suggest yout o go to near by Mall and find the same model and know the instruction first,this will help you most.
Hope i have solved your problem.
Please rate my Solution.
Thanks.
Mzas.
Posted on Jan 13, 2009
How do you brew a pot of coffee? Someone gave us a machine for our wedding and it just sits on the kitchen counter doing nothing.
I'm assuming you've got a coffee filter pot as this is the most common kind (especially as wedding gifts).
1. Boil the water.
2. Put the filter (should come with the pot) into the filter holder.
3. Add 2 level tbsp. of ground coffee per 6 oz of water.
4. Pour some of the hot water over the coffee grounds, giving them a few seconds to swell.
5. Now add the rest of the hot water and allow the coffee to slowly drip through the filter.
6. Remove the filter with the coffee grounds in just before the final drops of water go through.
7. Now sit down and enjoy!
Feb 25, 2013 | Home
How do you clean this product using vinegar?
Put a small amount of vinegar in the coffee pot, fill with water "12 cups" add contents to main unit and turn on, when finished! empty pot in sink and refill coffee pot with water only and cycle it through three to four times to make sure the vinegar is flushed out of the lines, adding fresh water each cycle.
May 19, 2011 | Mr. Coffee 12-Cup Programmable Coffeemaker
Coffee is sooooooooooooo weak!
Had the same problem...the temp thermostat that tells it to turn off when it reaches the right temp is going out so it doesn't reach the right temp to brew the coffee. The only way to check it is to use a cooking thermometer(digital works best)and run the pot through a cycle but don't add any coffee. Once done, stir the water in the pot just enough to get an accurate temp reading. The temperature of the water should be at least 185 degrees. I don't have a solution for you, I just bought another one... waited till Kohl's put it on sale and used a coupon I received in the mail. Sorry :(
Jan 19, 2011 | Faberware FCP240 Coffee Maker
Lost instruction manual. How do I clean coffee maker to get rid of strong acid taste coffee? MoldelB60 single cup coffee maker
Most coffee pots are cleaned by running 1 part white vinegar and 1 part water. Just put in the reservoir and run a cycle. Once completed, run again with 1/2 pot of water only and it will clean it. If you use your pot daily, this should be done once every few months. If you have foul tasting coffee, you should use bottled water to rectify that. Plain tap water has minerals that dilute the taste of the coffee and over time build a residue in your pot.
Oct 09, 2010 | Keurig B60 Coffee Maker
Self cleaning the quisinart coffee maker
I always use a mixture of 50:50 of cold water and white vinegar to help clean the internal parts of any minerals and scaling.
Unplug the coffee maker first, then add the water/vinegar mix to the reservoir.
Place a new, clean paper filter in the basket to help catch any deposits that will be dislodged and cleaned from the coffee maker.
As far as having the coffee pot dry, there is no need for that. I do tend to wait about 15 minutes to let the cleaning mixture disolve any deposits in the main water reservoir and then I turn on the coffee maker and let it process the water/vinegar solution through it.
Once it's done, turn off the coffee maker and discard the solution in the pot. And rinse out the coffee pot/carafe with clean, fresh cold water. Remove and throw away the used paper filter element andrinse out the basket with warm water and put it back on the unit.
Now fill the coffee pot/carafe with fresh, clean water and pour that into the coffee maker's water reservoir. Put in a new, clean, paper filter and turn the unit on and run a plain pot of water. This will help to clean out any remaining residue and clear the unit of the vinegar taste and odor.
Now you're all set to start making fresh tasting coffee again. I always recommend using filtered water for the best tasting coffee, as the taste is a direct result of brewing temperature, water purity, and the coffee you use.
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Cuisinart DCC-1200 Coffee Maker
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam...
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Jun 11, 2009 | Wega Mininova EPU Espresso Machine
Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
Jan 11, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Mr. Coffee 12-Cup Programmable Coffeemaker Logo
651 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Jim London
Jim London
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
