Postcode checker for DAB to check for signal
Would this radio work in my home + if so what quality would i be able to listen to all the channels
2 Suggested Answers
  • 71 Answers
SOURCE: DAB radio model Sharp FV-DB1E
This is SwannerX and I have solved the problem by locating the DAB radio receiver to a higher position ( some 6ins. higher only ) and orienteering the aerial in an opposite direction.
All 25 stations now tune O.K. and signal quality still reads in the high 90's and signal strength shows 9-10 bars. This is not substantially any more , but it has done the trick!!!
I am still very puzzled why it would not work again in the original position where it has worked well for many years.
Obviously DAB requires a good strong signal as I am living very close to the transmitter at Mounteagle in the Black Isle and the set is upstairs in the house to achieve the highest signal into the set's whip aerial.
Another annoying query I can give you is this :- Every time I do a full AutoTune operation on the DAB receiver , it ALWAYS comes ON tuning BBC Asian 1st. so that station comes up as a 'Favorite' on the Radio's screen. No matter how many other stations I select and listen to for at least 20secs. say, the BBC Asian one STILL is listed as a FAV.
Is this a peculiarity of the Sharp design or a function of the transmission system?
Maybe this BBC Asian is on the first freq. the DAB Radio scans, but I would have thought it would come ON every time with the last station which was selected before it was switched OFF.
What do you think ???
Posted on Feb 26, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
How do I find out if I can get DAB radio in my home of St. Just Cornwall?
Google "UK DAB Coverage" and enter your Postcode to any fo the websites that come up. Unless there is a local repeater,the nearest transmitter will be Caradon Hill or Redruth - You may need an external aerial for crackle-free reception.
Sep 12, 2014 | Audio Players & Recorders
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Dab signal
I suggest you scout around the neighbours for a DAB you can borrow to test the signal in your usual place. Your own radio could be faulty.
One of my DAB radios worked fine on FM even though one day it just stopped working on DAB for no apparent reason. The board to repair it is priced not to sell...
Sep 17, 2017 | Audio Players & Recorders
HOW DO I GET MY CDAB5IR STEREO DABRADIO TO WORK
The first thing is to consider what DAB signal quality you have there. It might not be strong enough. Digital radio is not like AM/FM, it simply goes off altogether if the signal is weak.
I would take it to the shop and ask for assistance, or get next to a DAB radio which does work well. Then recheck things like settings, tuning, and a good battery in it (I think that model is a smallish radio?)
Nov 04, 2013 | Audio Players & Recorders
Philips MCB204 problem with tuner , DAB and USB
Is the MUTE button activated? Press once to ACTivate or INactivate
Apr 07, 2010 | Philips Audio Players & Recorders
Why, when listening to DAB radio in the car (professionally fitted) is some of the speech occassionally repeated ?
Thanks for writing to Fixya.com.
Although the DAB signals are less prone to interference, they're currently weaker than FM signals, which can cause problems if you're in a fringe reception area .Please check into this. Moreover DAB radio stations are "compressed", so that lots of stations can be squeezed into the available bandwidth. Because of this compression, some stations on DAB are not in as good a quality and you are getting repetition issues. Thanks for contacting Fixya and please accept the solution if it has helped you.
Mar 31, 2010 | Car Audio & Video
FITTED A SONY CDX-DAB6650 RADIO BUT WHEN IT CHECKS
yes you prob will do as you need a very good signal for dab radio the one supplide is like using a wet peice of string ie not very good
Oct 12, 2009 | Sony Car Audio & Video
Feb 22, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
