What does the directory services restore mode do?
  • 2,878 Answers
Restarts the Domain Controller in in a network. Not something that you want to do. It might bring down the network and knock users off line by preventing access to network.
No affect in home use.
Posted on Dec 11, 2012
2 Suggested Answers
SOURCE: trying to restore acer netbook to factory defaults
Insert your Operating System recovery CD then try to turn off the computer, remove the cables and battery. Then press and hold the power button for 8 secs. Reinsert the cables and battery. Press and hold F12 while turning on the computer. Select the CD/DVD ROM under boot device menu. Press any key to boot from CD. Then select English > then select Custom > then select Disk 0 partition. On that manner, your system will install fresh copy of your operating system and will restore your pc in factory default..
Posted on Aug 17, 2010
Dafina zeqiri supernova
What sort of a problem ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Aug 24, 2013 | Computers & Internet
Hp intel core i5 suddenly goes black screenbut still on, how to fix black screen
run a system restore in restore mode. @start up press f8 to get to your start-up options menu. select the one that says directory services restore mode. you've gotten some malware and its messin with your video drivers. i had the same thing a while back. after you get your screen on i highly suggest backing up everything important to you and take it to a shop to have the malware properly removed
Aug 18, 2013 | Fujitsu LIFEBOOK LH531 14 Notebook - Core...
How can i get rid of Dxerror 8876086C
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 22, 2013 | Logitech QuickCam Computers & Internet
My pc was restoring with tun up360,restareted,and now windows dose not work
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 05, 2013 | Computers & Internet
Can u restore a emachines pc from the bio or boot logshelp
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
How do i restore the directory
In RPL mode, put the object on the stack. Enter the name you want for the directory (must not conflict with an existing object) between ticks and press STO.
Mar 18, 2010 | HP 48gx Calculator
How to repair dsa.msc it is not working
Reboot your DC in Directory Services restore mode and then try again. If you have a backup, then restore the backup.
Let me know if you have any queries.
Regards,
Abhay.
Apr 08, 2009 | Microsoft Windows Server Standard 2003 for...
Set up
the error that you have mentioned is related to a memory location so you might have a problem with the memory of the PC however I would try and boot the PC in directory service restore mode which is a protected mode in windows and try to install the program from here and see how it goes.
Directory service restore mode is very similar to safe mode however it has admin rights.
Mar 09, 2009 | Kodak Easyshare M753 Slim Digital Camera
Window 2003 AD NTBackup Problem
Reboot into Directory Services Restore Mode (F8 at startup) and use NTDSUTIL
to check the integrity of your database. Usually, an offline defrag will
fix this kind of error. If it doesn't, and the integrity checks fail,
you'll need to try and repair. Note that there could be issues with the
repair so be prepared to restore from backup.
Google NTDSUTIL for the syntax. There's loads of info. on TechNet2.
Feb 01, 2008 | Microsoft Windows Server Standard 2003 for...
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Dec 02, 2007 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
