Question about Logitech Z323 2 Speakers
The subwoofer makes a weird noise
When i play certain songs the sub makes a rattle sound when on pretty much every bass or volume level i put it on the sound comes from the inside so i need to know if i need a new one or just re-do step by step process
SOURCE: Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Posted on Jan 22, 2008
  • 3 Answers
SOURCE: headphone jack is weird...
HAVE YOU TRIED THE BEST QUALITY HEADPHONES LIKE SONY AND DID YOU CHECK YOUR COMPUTERS VOLUME?
Posted on Mar 27, 2008
aclamonte
  • 81 Answers
SOURCE: Crackling noise from subwoofer????
sgangsta91,
i think your speaker cannot support the sound that your computer produce. it means to say that, they are not compatible. specially when your computer sound interface that you used is 5.1 or 7.1 interface but your speaker specs is only for generic sound, you really hear a crackling sound and more if you set to higher volume.
but it can help if you only set your computer interface to generic sound or set only in lower volume it can help. because if you continue that way, your speaker can be seriously damaged that even at the lowest volume can hear the crackling sound.
or if you really want a fine good sound system then, buy a speaker that can interface with 5.1 or 7.1 or see manuals of your computer/motherboard. for recommended specs
aclamonte
Posted on Nov 15, 2008
SOURCE: Bass Flow Tube
Carefully pry off the gray metal mesh covering the speaker. Don't pry on the plastic ring - you have to remove the metal mesh from the plastic. Remove the six screws holding the speaker in place, and remove the speaker. Finally, re-glue the tube into the port. Wait for the glue to cure before turning the speakers on again.
Posted on May 19, 2009
  • 30 Answers
SOURCE: Logitech Z-2300 subwoofer/Bass volume cannot completely shutoff
Make sure the wired remote is connected completely and if that doesn't work try putting a pillow or a pile of blankets to cover both the subwoofer driver and the air port on it and that should reduce the sound coming from it. Also if it is in a corner or on a solid floor like wood or tile i would move it to a less enclosed space with carpet or a rug. Thats all I got I hope that helps.
Posted on Dec 15, 2010
What does the sw level setting do?
hello.. the sw level is short for your subwoofers volume setting .when you use a subwoofer thats powered and connect it to your recievers sub out,this is than a way to adjust the subs volume from your seating position rather than only adjusting it from the back of the sub.. i recommend putting your subs volume(on the back of the sub itself) to midpoint and playing a bass heavy song or movie and adjusting the sub level on the reciever to how you like it.. enjoy
Sep 11, 2010 | Audio Players & Recorders
Popping noise on my 12" type r subs
The subs are making that sound when the bottom out + when they reach full excursion be careful if it keeps happening eventually your subs will fail because you will end up damaging the subs voice coil.
Happy Booming
Apr 20, 2010 | Alpine Type-R SWR-1222D Car Subwoofer
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
Jan 12, 2010 | Car Audio & Video
Bass sounds muggy it rattles alot when volume is turned up. It just started to happen. What is happening? The bass from the head unit is at -8 while the subwoofer level is a +15.
Have you had it checked out, if it rattles when bass hits hard, it could be busted, have you had it up extremely loud before? If so, that is probably what done it, otherwise, I would call whoever you bought it from, and ask them if they know anyone who has had similar problems to yours.
Sep 03, 2009 | Eclipse SW8102.4 Car Subwoofer
My subwoofer on my philips 5.1 speaker system is constantly generating lots of bass noise even on mute.
I assume you are using XP. Try these steps.
1. Open 'Sound and Audio devices' in Control Panel.
4. Start playing a sound.
5. Set the volume control of the subwoofer to the middle position.
6. Open volume control and adjust Master volume to a comfortable level (i.e. until there is no hum).
Also make sure you haven't muted any sound device except microphone. I think your problem is you have set it to the maximum level. So decrease it.
7. Mute the sound and check.
Good luck! Let us know the result.
Jul 07, 2009 | Audio Players & Recorders
Sunfire True Sub Constant Hum & Thump on Initial Signal
IF THE SUB HAS AUTO SIGNAL SWITCH THIS OFF BUT TO BE HONEST IT SOUNDS LIKE YOU HAVE A SPLIT VOICE COIL.
Jun 20, 2008 | Sunfire True Sub Signature Subwoofer
100watt sub
There is a problem wwith teh power supply or the amp section. Does the noise remain constant or does it vary in volume? The sub should have a level control, does the noise vary with that control?
Dan
Mar 19, 2008 | Kenwood SW-38HT Subwoofer
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Logitech Z323 2 Speakers Logo
106 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
