I'm getting the registry file failure screen it
  • 7,627 Answers
If you unplug, remove battery, plug in, reboot to the system restore.
Posted on Dec 11, 2012
  • 13433 Answers
SOURCE: C0000218 (Registry file failure)
Windows cant access required registry files
if you have a xp cd, put it in, start the setup, and enter repair console.
In repair console you should see a
c:>
prompt, type cd windows
cd repair
copy *.* c:\windows\system32\config\
type exit after files have been copyed, overwrite if asked.
type exit
restart pc and try to start windows if this fails
go back to xp setup and perform a repair installation.
Posted on Mar 27, 2008
YUGI0H
  • 45 Answers
SOURCE: recovery of xp
The safemode may not be accessable probably because you have the Other Gadgets connected to the comp.
Turn Comp off...
Remove every thing(except Keyboard,mouse,monitor& power.)
Then Keep Tapping F8 to enter "advanced screen options menu".
***If the safemode would not enter then enter the safemode with command Prompt.
***Log on to your computer with an administrator account or with an account that has administrator credentials.
*** Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
if all this do not work and the OS is an OEM then the manufacturer of this computer should have a to Recovery the OS by formatting the comuter.
Posted on Jul 18, 2008
SOURCE: Dell Inspiron 6000 laptop will not bootup properly
I started having the same problem. I think my system recovery information is stored internally on the computer but I do not remember what that restore key is. Can someone please remind me?
Thanks. I cannot get beyond the blue screen and safe mode or anything like that doesn't seem to work.
Posted on Aug 25, 2008
masteria
  • 355 Answers
SOURCE: Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
Posted on May 09, 2009
mopar2009
  • 32 Answers
SOURCE: Cannot start up
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Posted on Sep 15, 2009
Toshiba satellite problems L775 can't get past "windows is loading files"
First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 03, 2013 | Computers & Internet
Tip
How to Fix Windows Errors on Your Own?
If you have encounter windows errors frequently, you can follow the methods below to fix it,
Method 1 Check the Recycle Bin
In such a scenario, the easiest way to resolve error code is to re-install the deleted file from the recycle bin. For this, go to the recycle bin and search for the file. If you find it reinstall, if you can not then simply download the error code file from a reliable website.
Method 2 Scan for Malware
Step 1: Enter Safe Mode
Keep your PC disconnected from the Internet, and don't use it until you're ready to clean your PC. This can help prevent the malware from spreading and/or leaking your private data.
To boot into Windows Safe Mode, first shut down your PC. Locate the F8 key on your PC's keyboard; turn the PC on; and as soon as you see anything on the screen, press the F8 key repeatedly. This should bring up the Advanced Boot Options menu; there, select Safe Mode with Networking and press Enter.
You may find that your PC runs noticeably faster in Safe Mode. This could be a sign that your system has a malware infection, or it could mean that you have a lot of legitimate programs that normally start up alongside Windows.
Step 2: Delete Temporary Files
Now that you're in Safe Mode, you'll want to run a virus scan. But before you do that, delete your temporary files. Doing this may speed up the virus scanning, free up disk space, and even get rid of some malware. To use the Disk Cleanup utility included with Windows, select Start, All Programs (or just Programs), Accessories, System Tools, Disk Clean Up.
Method 3 Fix Hardware Problems
btwwu.bak file error may also pop on your screen because of hardware failure. If this is the reason, then we advise you to use the Device Manager an in-built tool in Windows 7 and 8 to fix hardware failures.For this go to the start menu then control panel. Now click on the "hardware and sound link" and then click on the Device Manager. If you find any devices in red exclamation point, then this means this device is problematic.
Some newly released device drivers are not as compatible with the old hardware devices as the previous version. If you receive btwwu.bak error after you update certain device driver, it's advisable for you to download and install the previous version of the driver. If you can't find it, you can "Roll Back" the driver in your Device Manager.
Method 4 Clean and Repair the Registry
On your PC within Windows is an area called the Registry, which acts as a warehouse for computer options and settings. The types of settings and information files stored in the Registry include user settings (for a computer used by a single or multiple users), operating and non-operating system software, the ports being used and hardware settings. Any information that may need to be retrieved later is stored in the Registry.
Therefore, next time you cannot open an application and keep receiving an error message, then you must know that a registry error might be behind it. When the files accumulate on your PC, they take up all the registry space and corrupt the important system and DLL files also stored in the registry, thereby generating such errors. Now you can clean the registry manually.
Method 5 Update Your Windows System
Outdated Windows system is often the case to affect the effective performance of those applications and files, and make some functions and services cannot be used smoothly on the computer. So you should go to check whether there has been a newer update version of the Windows system available online, and install it on your computer if there is.
Generally, if you are not a computer professional who learns a lot about the computer system, manually fixing the error problem on your computer will be a long way to go, for that you should consider all of possible factors for this error problem and try all of the possible ways one by one.
Did it helps? To learn more information: http://www.windowserrortool.com/btwwu_bak.html
on Jun 26, 2015 | Hardware & Accessories
Windows won't start with safe mode (windows7 i meant)
Do you have the Restoration/Restore Disk?
If so pop it in the optical drive (CD/DVD drive), and when asked choose Repair.
(Non-Destructive Installation)
Post back in a Comment.
Regards,
joecoolvette
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
Toshiba laptop windows XP has a registry file failure! My home screen won't come up can't get f10 to work safe mode don't work what can I do
Try this fix from the Microsoft WEB site.
http://support.microsoft.com/kb/307545
If it does not work then -
The quickest and easiest fix is to re-install Windows XP, the laptop's device drivers and your programs.
Dec 11, 2012 | Computers & Internet
Registry deleted accidently unable to start laptop can it be restored with command prompt
Try booting up in Safe Mode and if it lets you boot then run a System Restore.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
Run a System Restore. Click Start/Programs/Accessories/System Tools/System Restore. (If you have Windows 7, click Start then in the search box type System Restore and look at the returned results from the search and click System Restore). Once you open System Restore you want to select a Restore Point (date and time) before you started having problems. In your case that would be before you deleted the registry). Don't worry System Restore does not delete any of your data, documents, music, pictures, videos or programs (unless the program was installed after the Restore Point you selected).
System Recovery on the other hand will Delete Everything and set your system back to when you first purchased it.
If the above steps don't work then yes, restore the registry from a command prompt. The Registry is backed up automatically when windows create a restore point using System Restore. From a command line prompt simply type: rstrui.exe
May 16, 2012 | Computers & Internet
When Power On, the computer appears to be starting, get DELL logo, then black screen, then "We apologize for the inconvenience. Windows did not start successfully. A recent hardware change or...
Hi
You didn't told us, what is the most recent updates you've done, i.e.: installing driver or software, or something like this.
Choose 'Last Known Good Configuration', if not worked, choose 'safe mode'
Please tell us your results
Good Luck
May 13, 2011 | Dell Vostro 1500 Notebook
I add downloaded messenger to my emachines ET1641-02w
e machines have problems like this. unplug it from the back of the computer for ten seconds, plug it back in, do a start mode> If this does not work try rebooting to an earlier time
Jan 09, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
