Question about Tecnik TKL9260 Front Load Washer
My washer is draining as soon as i feel it up to wash what wromg with it
  • Tecnik Master
  • 17,129 Answers
Possible that the controller unit or the water level sensor is faulty. Switch on and check the inlet valve to load water into the drum. check if the water is stopped when the set level is reached or else it can be fault on the level sensor.
Posted on Dec 11, 2012
Whats wromg with my washer
The seal on pump is worn and wet your pump.
You need to replace with new pump.
May 31, 2013 | Fisher and Paykel Washing Machines
I have Kenmore110 digital washer,it won't drain or
Plug off the mains from the wall. Take out the exit hose from behind washer to floor level to drain out excess water. Raise up your washer slightly or feel for 3 screws right under the front, bottom. Unscrew these and pull down - you will find the lint trap and filter. (You may find a hose capped here for excess water, if not -as above for excess water) Be prepared for water. Clean out and refit. See that the exit hose is fitted at correct level after the job. Your filter and pump shd be checked according to your usage.
If helped pl click so.
Apr 22, 2013 | Washing Machines
My Danby washer always drain the water when it fill the water up on the 3 and 4 water level setting. So I can't wash clothing at all. Hope get answer soon.
The answer is the drain hose. It must be routed higher than the machine or water will always drain. There is no actual drain valve.
Oct 07, 2010 | Danby DWM99W Top Load Washer
Water is draining out the bottom as soon as it
A HOSE CAME OFF--THE DRAIN HOSE HAS A CRACK IN IT-- THE OUTER TUB IS PLASTIC SO IT COULD HAVE A HOLE IN IT---THE DRAIN PUMP IS LOCATED FRONT BOTTOM OF YOUR MACHINE IT COULD HAVE WORN A HOLE IN IT (PLASTIC ALSO)
Oct 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My machine is going through a wash cycle and has stopped with a "drainage blocked" light
Look for a kinked drain hose. Make sure drain hose is not plugged. Remove drain hose from washer and inspect drain outlet on washer is not plugged. Stick your finger inside and feel for any clothing fabric ect blocking drain line. The washer may have a built-in screen that is plugged. You may need to remove the back cover of the washer and inspect drain hoses for any kinks or blockages.
Sep 26, 2009 | Bosch WFMC 3200 Front Load Washer
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Jan 07, 2009 | Kenmore Elite 45986 Front Load Washer
Stupid washer
Check inside underneath from front. Disconnect the hose to the pump from the drum. You probably have something stopping the pump from running. Like a coin or toothpick. Put your finger in the hole a feel for something there. Remove any foreign objects and put it back together. Try to run a cycle. Hopefully the pump wont need to be replaced.
Jul 14, 2008 | Kenmore 43142 Front Load Washer
Washer is not filling up
your drain hose is too far down in the stand pipe or is below the tub and is siphoning the water out soon as it fills pull the drain hose up should only be four or 5 inches in the stand pipe
Jan 20, 2008 | Indesit W 123 Front Load Washer
Tecnik TKL9260 Front Load Washer Logo
19 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
