Question about EnGenius EOC2611P 80211bg Wireless Access Point
I am not to configure Engunius access point ecb9500
I could not browse the set up wizard after i enter the ip address 192.168.1.2...... is there any alternative to use set up wizard?
4 Suggested Answers
Macs R We
  • 481 Answers
SOURCE: Trying to connect Blackberry to
It sounds like your AP is not set up to be a DHCP server. If you want to use devices with your AP that expect to receive addresses over DHCP, then you either have to enable the DHCP server on your AP, or enable one somewhere else on your network to which your AP provides access.
Posted on Nov 01, 2010
remt23c
  • 78 Answers
SOURCE: EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Posted on Oct 31, 2007
Macs R We
  • 481 Answers
SOURCE: Hi, I cannot setup my
You need to enable the DHCP server on the EOC-2611P. Then it will negotiate an IP address with your PC without you having to set one by hand.
Posted on Oct 27, 2010
I cant get into config my dap1360 by typein in the dlinkap or 192.168.0.50
just make sure that you belong with in the same IP range.
default DAP-1360 IP is 192.168.0.50
username : admin password : <blank>
change your PC IP address to 192.168.0.xxx (e.g. 192.168.0.2)
from there you may choose wizard or manual configuration.
you may change your DAP-1360 IP add according to your network settings in the office and you must change you PC IP address with in the same range.
Mar 24, 2011 | D-Link DAP1360 IEEE 80211n (draft)...
I just got a dap-1360 and i cant set it up when i type dlinkap or 192.168.0.50 in my URL it keeps sayin webpage cannot be found
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Access point configuration
Access is easy to configure, you just need to understand basic setup you need to do and just have to find the same options on the configuration page of any wireless access point.
Things to setup.
1. Local IP Address ( You will get default 192.168.1.1 according to your device guide, still you can set different (not recommended, if not expert) )
2. Setup WAN IP-This could be dial up connection (PPPOE) or Internet IP Address provided by your internet provider.
3. Setup Wireless access point SSID, this is what you will find when you scan for wireless connection available
4. Setup security settings. You can setup WPA or WAP to protect security. Just need to select and assign key/password which you will be asked while connecting SSID
Follow the link for exact information on how to setup your Access Point
http://www.tomsguide.com/us/asus-wl-wl330,review-233-3.html
http://support.asus.com/faq/asus-faq.aspx?no=E8D3A5FD-995C-D299-0AE3-FBF28AA04DA6&SLanguage=en-us
http://www.ddp.ru/upload/images/PDF/WL_HDD25.pdf
Hope this helps
Jun 02, 2010 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Can't scan
To test the hardware, use the product to copy a document.
1.open the scanner lid.
2.put a document face down on the glass.
3.close the scanner lid.
4.press the copy button.
make sure that the product connects to the network
ethernet connection
1.Disconnect the network cable from the back of the product, and then wait a few seconds.
2.Reconnect the network cable to the back of the product.
3.Make sure the other end of the network cable connects securely to the router or switch
4.Make sure that the lights on the router or switch are on.
5.Continue to "Step three: Print a network configuration page and find the IP address."
wireless network
  1. Make sure that the router or access point is on.
  2. Position the router or access point closer to the product.
  3. On the product, press the setup button , and then select the network option.
  4. Select the wireless setup wizard option. The product searches for the router or access point.
  5. Select the 'enter the new network name'(SSID) option.
  6. Type the service set identifier (SSID) or the name for the wireless network, and then select 'done' . The product searches for the network.
  7. Select the relevant authentication protocol, also called the security mode. Supported protocols include WEP (64 bit and 128 bit) and WPA-PSK (WPA1 or WPA2, AES or TKIP). Networks that do not use an access point or a router, known as ad hoc networks, support WEP encryption only.
  8. If the network uses media access control (MAC) address filtering, make sure that you have the router or access point set to allow the MAC address for the HP product.
  9. Follow the instructions to configure the product for your method of network security:
  10. WPE: Log on to the router or access point from the computer, and then find the wired equivalent policy (WEP) key set within the router or access point. If you specify the WEP by using 10 or 26 hexadecimal characters, make sure that the characters are 0-9 and A-F. Use the on-screen keyboard on the control panel display to type the WEP key on the product.
  11. WPA: Log on to the router or access point from the computer, and then find the Wi-Fi Protected Access (WPA) passphrase set within the router or access point. Use the on-screen keyboard on the control panel display to type the correct WPA passphrase.
make sure that the product is connecting to the network, print a network configuration page from the product and find the IP address on the page.
1.On the product control panel, press the Setup button
2.Select Network , select Network Settings , and then select either Print Network Settings or Print Network Configuration Page . The network configuration page prints
3.Make a note of the IP address for the wired or wireless connection. The IP address should resemble the example: http://192.168.1.1
4.If the computer connects to the Internet using a wired connection, the IP address displays in the Wired section.
5.If the computer connects to the Internet using a wireless connection, the IP address displays in the Wireless section
Jul 21, 2009 | HP Officejet 4315 All-in-One Printer
Network key
Hi gamejunky,
in order to get your WPA key on your router you will need to access your internal router configuration.  To do this you will need first your default gateway IP address, that is your IP address of your router.
If you are not sure what it is you will have to check your network settings, and under TCP/IP look for Default Gateway.
Once you have the IP enter it into your web browser address bar and hit enter.  You will then be prompted for a login to your router which should be default unless you set it.  The default is usually "default" or "admin" or "password" or some variation.
After this you should browse to your router security settings section and under WPA enter in a shared key.  Write it down somewhere safe, and you are done!
Hope this helps, and please take the time to vote!
Mar 13, 2009 | Apple AirPort Extreme Base Station
Cannot connect dlink 1150 access point to my HP 550 laptop
go for the default ip address like 192.168.1.1 or 192.168.2.1 or 192.168.0.1 this default ip address you just try to go the router or access point page and then just configure it through the user manual in the CD try it.
Mar 12, 2009 | Computers & Internet
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Configuration
The best way to set this access point is to connect your computer directly to the device via Ethernet, disble the wireless adapter temporarily on the computer. Since this is just an access point and not a wireless router, it is not capable of providing your computer with an IP address because it has no DHCP functionality.
The IP address you mentioned is the deafault IP address of the access point, there is a posibility that the default IP has been change.
Do a reset on the access point then assign an IP address manually on your computer(i.e 192.168.1.x x- bein any number from 1 to 254 except 50)
Access the AP using Internet Explorer or Firefox, type http://192.168.1.50 on the address bar it should prompt you for a username and password(check you documentation for the default username and password for the access point)
Aug 09, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Software problem
There is usually an IP address you have to type to get access to this hardware. Often you don't need the CD to install this hardware. The IP address is usually 192.168.0.1 for routers. Sometimes they differ. To find out if you go to start then run. When a box appears type in there cmd then press enter on your keyboard. This should bring you to DOS. Black page with white text. If you type into that box ipconfig and then press enter on your keyboard.The IP address you see net to the default gateway is your router address. Writed down those numbers and that box you are in just type the word exit and press enter on your keyboard and that box will disappear.Type that IP address into your address bar by opening up your browser. This will bring you to the hardware page of your router.You can do all the confguring from this page. Sometimes a box with user name and password appears. The username is usually admin and the password is either password, admin or these is no password so you just press enter on your keyboard and then when you're in start configuring. Run the setup wizard first before you do anything else. Then I would go to wireless and password protect your network. I usually password the router as well. This option is in the setup wizard you did earlier. Good luck
Jan 21, 2008 | Actiontec GT701AP (DNHGT701AP) 802.11b/g...
EnGenius EOC2611P 80211bg Wireless Access Point Logo
75 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
