Question about Frigidaire FDE336RE Dryer
I have a FDE336re2 frigidaire dryer. I have replaced 3 thermal limiter switches and the 3204267 Frigidaire Dryer Safety Thermostat. The exhaust is clear. I operated the machine with the entire top lid opened so the interior would stay cooler and was able to do 4 dryer loads (at med heat) before the limit switch blew again. What else could be the problem!! ?
    Habit-Forming:
    New Friend:
  • 20 Answers
Try running the dryer with out the vent hose connected see if the problem persists. This will eliminate the ventilation system of your home from the equation. Then if problem persists must gointo the dryer.
Posted on Jul 19, 2014
2 Suggested Answers
  • 512 Answers
SOURCE: Thermal limiter stops dryer; replaced multiple times. Dryer dead.
I think you are working on the wrong end. Check the fan and inlet ductwork of the dryer, if the air isn't moving properly, it will not move enough to keep the coils and limiters cool and they will fail after working properly a few times.
Posted on Sep 03, 2009
Dryer not heating
Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire dryer is not heating. This could be a potential issue with your heating element, timer, or thermostat. In order to accurately check each part you would need to disassemble your dryer and test each piece for the proper continuity. This is not a simple DIY job and I would highly suggest contacting a professional technician comes out for proper diagnosis and repair. Best of luck! -Matt
Apr 20, 2015 | Frigidaire Dryers
Fde546les0 frigidaire dryer blowing thermal limiters
If the fan is running and all duct work is clear, the control thermostat/s will need replacing as they are not switching the heaters off when up to temperature, the dryer then overheats and the thermal limiters blow.
Aug 03, 2014 | Frigidaire Dryers
Test high limit thermostats
Good Afternoon Friend,
I understand that you are trying to test the high limit thermostat, or thermal limiter, on your Frigidaire dryer, model# GLER642A. Typically, this is not a do it yourself job. There are no manuals that will explain how to test the thermal limiter. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer and be able to better assist. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire GLER642A Electric Dryer
Dryer has power wont start
Hello Dom - Being that you have narrow down some possibilities, here are a few simple troubleshooting tips that may help you get to the root cause:
1. Make sure the dryer is plugged into outlet, and plugged in correctly.
2. Is house fuse blown or circuit breaker tripped? Replace fuse or re-set circuit breaker.
3. Make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. I would recommend reaching out to a Licensed Electrician check to make sure it is on a circuit by itself.
4. Thermal limiter tripped or an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation.A service technician must replace the thermal limiter after correcting the fault.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jun 19, 2013 | Frigidaire Dryers
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have fridgidaire dryer and when I push the start button it just makes a buzzing noise but does not start
Unplug the dryer or disconnect power then remove the two screws securing the top panel to the rear and slide the panel backwards and off.
Behind the drum is the thermal limiter which is wired in series with the motor.
Check the continuity of the thermal limiter and if it reads open, replace it including the high-limit thermostat located on the heater housing (also shown in the picture above). Bypass the thermal limiter for troubleshooting purposes by joining the wires together and insulating it properly. If the dryer starts and runs properly with this setup, the thermal limiter is indeed open. If the dryer still does not start, jump a wire between the COM and NO terminals of the door switch. The dryer should start with the thermal limiter and door switch bypassed, otherwise bypass the motor relay on the control board. Replace control board if the dryer starts with the three bypassed, otherwise the motor is the one at fault and needs to be replaced.
Aug 21, 2011 | Frigidaire Electric Dryer
My dryer keeps blowing the thermal limiter fuse or switch,what ever it is called.why?
Hi candwloc..
If the thermal fuse /thermostat overheats the dryer will not operate.
It's located on the blower housing and it cannot be reset.
A vent clogged with lint can cause the dryer to overheat and keep blowing the thermal fuse/thermostat.
You can test it with an Ohm meter or continuity checker, if no continuity, replace it.because it is faulty.
Please take time to rate me
Jul 24, 2011 | Frigidaire FEQ332E Electric Dryer
Dryer do not spin if thermostat is plugged
Ok. The model number pulled up a stack unit and a regular standalone dryer. Im refering to the standalone Dryer.
Your Temp control thermostat is located in the front of the blower housing in the front of the machine, part # 134048800
the thermostat that your jumping is either the thermostat on the heater housing, Part # 3204267
or the Thermal fuse on the back wall,
Part # 134120900
If you have not changed the Thermostat on the blower housting, this is why you have not solved the problem.
Make sure your heater coils are not shorting to ground as well.
Make sure to replace the thermostat that your jumping and the one on the blower wheel. and as always make sure you unplug the machine while you work.
Jan 08, 2010 | Frigidaire FSE748GF Dryer
Sep 03, 2009 | Frigidaire Dryers
Frigidaire dryer
there are several issues that can cause this most common is the vent restricted backing up heat in the dryer if its as old as you say you need to check the whole vent system it has to be 4inches dia all the way if its mashed or drooping under the house its restricted if its folded over or mashed behind the dryer its restricted the thermal limiter is a safety thermostat it opens about 300 degrees to prevent fire the dryer has three thermostats an operating thermostat a safety thermostat and the thermal limiter if the operating thermostat fails then the safety thermostat takes over and cycles on about 165 on and off if both thermostats fail then the thermal limiter opens about 220-300 depending and it doesn't reset and cuts all the power to the dryer till a tech can check everything i just told you about so if your vent is clear and the best way to vent is 4inch pvc drain pipe 90 it up behind the drier then connect with a short peice of metel vent then just replace all three thermostats
May 21, 2008 | Dryers
Dryers Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
