Question about Galaxy G18-AT Popcorn Maker
Galaxy popper g12 unpopped kernels
This machine had been working fine. Suddenly it began leaving alot of unpopped kernels. Seems to pop half a batch and then stop.
The problem you are having is the thermostat inside the kettle is getting weak these can be ordered from Star Manufacturing or a concessions supply place that does repairs Also Gold Medal Product has a similar thermostat that will work in your kettle pt# 47082 Just a FYI
Posted on Jan 13, 2009
Nostalgia Popcorn Maker CCP399 - when the popcorn is popped, unpopped kernels come out with the popped kernels. How can I stop this from happening? Thanks!
You cannot. All poppers of that style will a some "fall out". The better commercial machines have very little as the kettles are deeper, but you cannot eliminate it. The unpopped kernels are not reusable.
Oct 24, 2013 | Nostalgia Electrics CCP399 Vintage...
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
We are looking at buying a cretors popper Model D1 or DI 20cp , Volts 120/208-240, watts 4200 What we want to know is how old is it and how many ounce machine is it The info we have was given to us by...
A DI 20 is a 20 oz. Diplomat, meaning the kettle is designed to accept 20 oz. of unpopped kernels per batch. The date of manufacture can be determined by the serial number. The first two numbers are the year in which the machine was built. For example a serial number starting with 95 was built in 1995. You can try finding a manual for the machine at the manufacturer's manuals website: http://74.222.63.157/Net2009/DocLoc-set.htm. Or visit www.cretors.com.
Jan 28, 2011 | Cretors Goldrush Popcorn Maker
I purchased the stir crazy model 82306 and it does not pop the corn properly. Less than half of it pops. I have never had this problem with other West Bend stir crazy poppers in the past. On 4 separate...
I have one of these poppers and have been impressed with the minimal number of unpopped kernels.
On only one occassion have I not been satisfied and suspect it was due to insufficient oil being added.
Make sure you are adding sufficient oil to aid heat transfer to the kernels.
Jan 16, 2011 | West Bend 82306 Stir Crazy® Popcorn...
I have a presto hot air corn popper and can't remember how to use it, particularly hot much corn to put into the popper. The model number is 01/pni. Could you please help me as soon as possible, as I...
Does your popper have a butter melting cup at the top? (The one we had years ago did.) Remove that cup from the popper and fill it with the unpopped kernels. (Fill loosely to level with the rim of the cup or less. Do not pack the kernels into the cup or overfill.) Then pour the kernels into the poppiing chamber. There should also be a fill line inside the popping chamber that indicates the maximum amount of popcorn to put in the chamber. Then put the measuring cup/butter melter back on the top of the popper.
The manual for the current Presto Hot Air Popper is available as a PDF from the Presto site. The list of all their popcorn makers is here: http://www.gopresto.com/products/products_search.php?search_value=37&operation=Search&search_type=category . To find the manual click on the hot air popper and scroll down, the user's guide is listed under the parts/accessories available for sale. The current one looks identical to the one that my family had ~20 years ago.
I hope this helps.
Dec 21, 2010 | Presto Kitchen Appliances - Others
ALL THE KERNELS ARE NOT POPPING
There are several possible culprits for your Kernel Caper.
1) You may need to add a little more oil to the kettle. Let it come to full heat--just as soon as the oil starts to smoke.
2) The corn you are using must be reasonable fresh and have sufficient moisture to pop the kernel. You can try putting 1 tsp/1 lb of corn in a ziploc bag or screw top bottle. Leave for 24 to 48 hrs to let the corn absorb the moisture.
3) Finally, due to the small size of the popping kettle some kernels will be thrown from the kettle from other kernels popping open.
This is a great little popper. You might have some luck decreasing the size of your batch--reduce your oil and corn by 1/4 each.
Good Luck
Sep 24, 2010 | Maximatic EPM450 Popcorn Maker
Lost the instructions for a nordic ware microwave corn popper
1. Pour up to 1/3 cup of popcorn kernels in the base of the Popcorn Popper.
2. The use of oil is optional, but not necessary. If desired, drizzle a small amount of vegetable oil over the unpopped kernels, then stir to coat the kernels.
3. Place cover on the base bowl. Cook on High in the microwave for approximately 3-5 minutes (microwave ovens vary tremendously!), or until popping slows down. Allow Popcorn Popper to cool before repeated use. Do not try to re-pop unpopped kernels.
4. Hand washing is recommended, but occasional washing in the top rack of a dishwasher is acceptable for the bowl, but not the lid.
5. If popcorn burns easily or does not pop well, try placing a shallow bowl, dish or plate upside down on the microwave turntable to raise the popcorn popper up a bit.
Jun 27, 2010 | Kitchen Appliances - Others
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Heating element
What size kettle?
It is probably the thermostat
Oct 31, 2007 | Gold Medal 2086 Popcorn Maker
Kitchen Appliances - Others Logo
433 people viewed this question
Top Galaxy Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Galaxy Kitchen Appliances - Other Expert? Answer questions, earn points and help others
