Question about Deco Lav DECOLAV Decobronze Push Button Closing Umbrella Drain Without Overflow
I have a decolav drain in a stone sink. The sink drains very slowly when I push down the button. It seems to drain on the outer circumference of the push-down fixture. The sink is stopped when the button is pushed again, even though that is when the button slightly pops up? How do I adjust the mechanism so that it will drain smoothly? fixture o
2 Suggested Answers
  • 17 Answers
SOURCE: where can I find parts (seals) for the decolav
Take it to a auto supply and have them match the "O" ring. Or try a bearing and seal supply (specialty) if auto parts supply store doesn't have it
Posted on Jul 05, 2009
The drain will not drain
If its in the drain it could be hair caught up around the stopper or caught up in the trap. It could also be further down the line, such as if your in Michigan it could be a frozen pipe.
Mar 05, 2014 | RTO Decolav 9298-cp Push Button Closing...
My decolav pop up drain will not open. I have to screw it on and off to use the drain.
If you can remove the pop-up part you probably will find it is clogged with soap residue and goodness knows what else. You will have to disassemble it, making note of the parts order and scrub all parts clean using an old toothbrush. Reassemble the pop-up in the proper order and you should be back in business
Mar 03, 2013 | RTO Decolav 9298-cp Push Button Closing...
I have the Decolav 1201 SS sink under-mounted to my granite counter. It appears that I need a special drain as none of the ones I saw available are for sinks that are the thickness of stainless steel...
Did you add the rubber gaskets so they are on the underside of the sink? If they are on the underside of the sink, then I think you're modification is a good one, and I'm not sure the gaskets are the cause of slow drain. Not sure what would cause the last inch to drain slowly. Now, if the gaskets are inside the sink bowl (i.e. visible from above) and the drain tube is elevated up from the base of the sink bowl, then there's is a likely source for the problem...
Regards,
DIYpro
Jun 07, 2011 | Deco Lav DecoLav 1201 Simply Stainless...
Drain won't close
hi, the button can come out of the drain hole either by unscrewing it or some simply pull out, once it is out there is a threaded bolt attatched to it this can be adjusted by screwing it in or out
Jul 06, 2010 | Deco Lav DECOLAV Decobronze Push Button...
Can the umbrella portion be removed in order to get at the drain pipe itself?
Yes.. but it is tricky...you need to loosen the nut underneath the sink and then to use something to grab the top part like a plumbers plier to turn the top off. Most of the time you will have to ruin the top part to get it off...
heatman101
Apr 13, 2010 | RTO Decolav 9297-SN Push Button Closing...
Where can I find parts (seals) for the decolav push button drain?
Jul 03, 2009 | Deco Lav DECOLAV Decobronze Push Button...
Water drains slowly from newly-installed kitchen sink and gurgles as the last drops go down the drain
sounds like you have a partial blockage in wall pipe.take of p trap and snake pipe in wall as far as you can.
May 09, 2009 | Home
Deco Lav 9298 Closing Umbrella drain will not close
sounds like you need a new stopper i had the same trouble bought a new stopper they don't cost that much
Feb 27, 2009 | Deco Lav DECOLAV Decobronze Push Button...
Odor from Decolav bottle trap
there really should be a trap with a bend in it on the system at somepoint to prevent odour ingress?
Nov 22, 2008 | Deco Lav DECOLAV Chrome Polished Grid...
Deco Lav DECOLAV Decobronze Push Button Closing Umbrella Drain Without Overflow Logo
Top Deco Lav Plumbing Experts
Donni Steen
Tom Chichester
Are you a Deco Lav Plumbing Expert? Answer questions, earn points and help others
