Question about Sony VAIO SRX99 Notebook
Installing windows 7 on a Sony Vaio pcg-272L
This is a core2 system with 4gb memory. vista is factory-installed. can it run windows 7 ?
4 Suggested Answers
  • 20 Answers
SOURCE: I have a Sony VAIO PGC-272L that ignites the
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki99
Posted on Jan 03, 2010
walesarumi
  • 6993 Answers
SOURCE: The screen is white u
Firstly, connect your laptop to an external monitor and observe if there would be any display. If there is display, then it means, your laptop screen, screen flex or screen inverter is defective, that's why its not display.
If you know about laptop repairs you can dismantle the laptop, remove the screen and screen inverter, use another laptop to test it so that you can know precisely which is bad and make necessary replacement.
But if you cannot do this yourself, then you will be needing the assistance of a repairman to help you test which is faulty between the screen and inverter.
Good luck.
Posted on Oct 07, 2010
mariolands
  • 2296 Answers
SOURCE: sony vaio pcg-272l all in one with catv connection
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Dec 25, 2010
Can i install 64 bits of window 7 on my Sony VaioPCG-7D2L
Technically Yes, you can.
However, your laptop is quite old now, and may not be suited for 64-bit Windows. You can install and run Windows x64, but it may be slow and unstable.
Why do you need 64-bit?
If you don't plan on running a 64-bit-only application or you have more than 4GB of RAM, chances are you wouldn't need a 64-bit windows installation.
Feb 01, 2014 | Sony Vaio PCG-7D2L PCG-7A2L PCG
Sony vaio pcg-7g2n sound driver for windows 7
Hey,
Sony vaio pcg-7g2n Driver Download offers an overview of the drivers are installed, as well as links to be able to bring to download for Windows 7, Windows 8, and Windows 10.
When installing drivers for Sony VAIO important to follow the correct sequence of installing these drivers in order to avoid problems with the work of the function keys: volume+Fn, brightness+Fn, input switching+Fn, and others.
Drivers Download
Jan 01, 2014 | Sony Computers & Internet
Memory not recognized
A Windows OS that runs on 32bits cannot use more 4GB, in fact it is closer to 3.3 GB. If you want to use more than 4GB you will have to install a Windows version that is 64Bits (Windows XP, Vista or Windows 7).
Aug 20, 2012 | HP Computers & Internet
I am buy ram 2gb bus 800 two pcs that was 4gb bus 800 in the two slot when I rest PC;show 3.xxx Total memory That most be Show 4.xxx . How I do?
This motherboard does support 4GB RAM, however, if you are running a 32bit OS, like XP, Vista 32 and Windows 7 32, you may only see 3.5GB as this is a limitation to 32bit. If you are running 64bit Vista or Windows 7 you will see the full 4GB.
Regards, Chris
May 13, 2011 | Gigabyte GA-945P-S3 Motherboard
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
I upgraded my SONY VAIO VGN-C2S/H from vista to windows 7... but its not recognizing memory stick
Go on sony website and dowload the proper drivers for your machine. The old drivers from vista might not work properly in 7. I, personaly, recomand a fresh clean install in the upgrading cases. That means to format the HDD and install everything from zero. Upgrating from an OS to another by installing an update patch is not a big deal. There might remain some dirty registry wich will make the sistem running slowly.
Jan 25, 2011 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
How much RAM should I put on my evga motherboard the Supermicro X8DTN+ Motherboard
This depends on what windows you run and what kinda programs are you going to run. Like if you run lots of games you need more memory and if just doing like internet surfing or writing documents then less. 32 bit operating systems can see up to 4GB of memory and 64 bit Operating systems can see i believe up to 16GB or so. Windows vista and windows 7 need more that xp. For windows vista and 7 it is recommended to have at least 1GB for basic operations so i would recommend at least 2GB. The more the better for the feed back from the computer. More memory more programs you can run at once. Hope this helps.
Nov 07, 2010 | Computers & Internet
Installed 4 G of RAM. Installed Windows 7. Only 3 G RAM Usable
To recognize more than 3GB of RAM you will need a 64 bit version of the operating system. If you install Windows 7 32 bit (normal for most users) you will only see 3.
You should have both versions of Windows 7 (32bit and 64 bit) on your installation disk. However you will need a 64 bit capable processor to install it. Otherwise 3GB of RAM for a 32 bit operating system is more than enough.
Mar 08, 2010 | MSI PT880 Neo FSR Motherboard
Sony VAIO SRX99 Notebook Logo
83 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
