Question about Ricoh 4506 Copier
Does anyone know how to turn the sleep mode on for a Aficio MP4000 photocopier
  • anspack Jan 15, 2009
    Never mind. I figured it out.
  • 183 Answers
You can do it by pressing the energy saver key it is next to the number " 3 "on the control panel or you can put a certain time when the machine will go to sleep.
1. press the [user tools] key it's on the right side under the copy key.
2. press [system settings] on the touch screen.
3. press [timer settings] on the touch screen.
the time can be set from 1-240 min.
it means after how much min. do the copier to go to sleep mode
Posted on Jul 12, 2009
Interface setting not appearing in Ricoh mp4000
it is your scaner and power cable problem
Nov 18, 2014 | Ricoh Aficio Mp 4000...
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
How can I turn off the warning beep on the Alficio MP4000?
You should be able to find this under user tools -system settings
Feb 22, 2010 | Ricoh Aficio 450 Copier
Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Jan 21, 2010 | Office Equipment & Supplies
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
Large broad grey lines on all photocopies
Hello sir; The problem you have , you do need a drum cleaning blade to replace and also image transfer roller need to clean with alcohal.
May 26, 2009 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Ricoh photocopier 1075 code sc541
Ok, its a firmware bug, but you should be able to reset it. Press clear modes, 1, 0, 7, and press and hold clear/stop. Press 1 for copy sp. Scroll down to 7, (data log) press 7. scroll to 7807, and reset it. exit all the way out, and recycle the power.
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh 4506 Copier Logo
274 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
