Question about Sharp EL-310AB Calculator
Square of number
I have a EL337M calculator. I can see the Sq Root button, but there is no square button. ie 3^2=9 Can anyone help? THANKS
SOURCE: FIX numbers
If you press the setup key then 1 under FSE it will say TAB (0-9)? enter the amount of decimal places you want and it will change that for you.
Posted on Apr 20, 2008
0 characters
1 Points
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
Feb 03, 2015 | Casio fx-115ES Plus Scientific Calculator
Does my ti-86 solve sq. root problems
Yes, your Ti 86 should solve square root problems. At the HOME screen press [CLEAR] [2nd] [x^2] which gives the (Square Root Symbol) to display at the Home screen. Then enter the number you want the square root of and close the bracket [ ) ] and, press the [ENTER] key.
You can even get the square root of complex numbers too. Select the correct complex format in the mode settings. For example: I'll do one in the rectangular form by enter a number as (a, b). I then will go to [2nd] [MODE] then [Arrow down] 3 times and make sure the RectC is highlighted and selected. Then quit out of the mode settings screen and enter [CLEAR] [2nd] [x^2] [ ( ] [9] [ , ] [ - ] [4] [ ) ] [ ) ] [ENTER], this displays the SQRT((9,-4)) equals (3, 2); The real part is 3 and the imaginary part 2.
Jan 09, 2011 | Texas Instruments TI-86 Calculator
Need to know how to do squre roots step-by-step
type 2nd then the square root sign and type in the number u need. the close off the parenthesis and hit enter
Sep 25, 2009 | Casio FX-300MS Calculator
Can you please explain to me what 1/x, x2, and checkmark x are?
1/X is the number dividied by x ie 1/2
x2 is the number times itself (squared) 2x2
what checkmark X sounds like is actually the square root of the number ie sqrt of 9 is 3
Jul 09, 2009 | Texas Instruments TI-30XA Calculator
Using my Casio FX-115ES
Use the key that is 3 keys below the ALPHA button. You must press that key, then place the number or equation you are trying to get the square root of.
Apr 13, 2009 | Casio FX-115ES Scientific Calculator
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Dec 01, 2008 | Texas Instruments TI-30XA Calculator
I need some help please : )
The parenthesis is there so u can put a number under the radicle. Just close the parenththesis once u put the number under the radicle
Aug 08, 2008 | Texas Instruments TI-83 Plus Silver...
Square root on FX-83ES
make sure you havnt droppend your calculator as this can damage the chip, if so , re solder broken parts and it sshould work, this happened on mine and after i soldered it it is fixed.
online companies can fix it if you send it away
Jun 07, 2008 | Casio fx-300ES Calculator
Sharp EL-310AB Calculator Logo
27 people viewed this question
Top Sharp Calculators Experts
D. E. Hev
Are you a Sharp Calculator Expert? Answer questions, earn points and help others
