When I try to light my emberglow gas logs the pilot goes out and it will not light.
3 Suggested Answers
  • 17 Answers
SOURCE: Pilot on logs won't stay lit
Hold pilot button longer. if this doesn't work your Thermopile has gone bad and will not generate enough Millivolts to keep gas valve pilot open. A new thermopile will generate 750 millivolts. It cost less than $20 dollars but is difficult to replace. You should call a certified technician. They will charge you about $100.00
Posted on Oct 27, 2009
  • 4736 Answers
SOURCE: i have a flavel emberglow
From what you described it sounds like the Oxygen Depletion Sensor (ODS) may be partially clogged with dust, lint and/or pet hair. The ODS is a safety device, that shuts the system down if it detects that there's not enough oxygen for safe combustion. It can be cleaned with a can of compressed air with a straw nozzle (like you clean your computer with).
Remove the logs from the burner and carefully set them of to the side, out of the way. I should mention here, the logs have to go back in the exact same position and configuration that they were in, before you took them out. So, keep that in mind. Better yet, find your Owners Manual or take a picture of the setup, before you remove them.
Once you have the logs off the burner(s), use a vacuum that has a hose and brush attachment and vacuum the burner(s), the grate and any cobwebs you see in the firebox. After completing the vacuuming, look at the Pilot Assembly. Tank the can of compressed air with the straw nozzle attached and blow out the pilot tip with a quick blast of air. Now, log down the pilot from the tip. About 2/3rds of the way down, you will see a hole in the side of the pilot. That's the ODS sensor. Place the tip of the straw nozzle just barley into that hole and give it a quick blast of air. You may see debris come out the other side. Now, reinstall the logs on the burner, the exact way they were before you removed them. Light the pilot as you normally would and once it lights, hold the Control Knob in for 1 minute. Ease of the Control Knob and turn it to the ON position, Everything should not work as it was designed.
Take a moment to pat yourself on the back. You just completed what's known as "Annual Maintenance." Which should be done at least annually. Usually in the Fall, before you light the gas logs for the heating season.
Hope this helped to solve your problem.
Rich
Posted on Mar 02, 2011
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Pilot light stays lit but burner on gas logs goes out
You may need a new pilot assembly. Typically one of two issues result from a bad pilot assembly:
1. The pilot won't stay on after lighting it
2. Pilot stays on but logs won't light.
Depending on the unit, you may need a new thermopile or a whole new pilot assembly.
Feb 02, 2014 | Home
Emberglow ventless gas logs (set to burn on porpane gas). Pilot lights, but not logs.
It needs 14'' wc to work , hose could be too small for load .
Dec 06, 2012 | Heating & Cooling
I have a flavel emberglow gas fire the pilot light works but when you turn the fire on it stays on for about 5min then goes out including the pilot light
Rich
Mar 02, 2011 | Heating & Cooling
My pilot light kept going out. I cleaned it
You may have to get a new thermocouple.
This is a small copper tube that goes from the pilot light area to tha gas valve.
It feels the heat from the pilot and keeps the gas valve open for gas to flow to the pilot or to the logs when in the lit position.
Without the gas valve will stay closed.
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
After about 5 years with no problems, the emberglow vent free gas logs are not igniting. the gas is coming out as i can hear it, but the ignite switch doesn't have any effect. if i hold a lit lighter in...
Sounds like a bad pilot sensor called a Thermocouple. It is a copper tube that goes from the gas valve to the pilot assembly. It is the smaller of the two tubes. They are available at better hardware or farm stores. It is best to unscrew it from the gas valve and pilot assembly and bring it with you when you shop for one. It is something any mechanically inclined homeowner can replace.
Dec 03, 2009 | Desa International CCL3924PTA 24" LP Gas...
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
I cant get the logs to light only the pilot light
Can you smell gas when the pilot goes out? If so, you may have too much pressure. If you just changed bottles and didn't do anything else, look at the flame sensor. It may be the problem. Good luck...Lee
Nov 12, 2009 | Blue Flame Charmglow 30K BTU Propane Vent...
Oct 19, 2009 | Desa International Wall/Window Air...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
