Question about Health & Beauty
How do I put back my blade on Oster model 254 - 01 series A
2 Suggested Answers
philschneide
  • 448 Answers
SOURCE: CHANGING BLADES
There is a small gun-metal colored bar (dark gray or black) at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Hope this helps you.
Posted on Apr 09, 2010
How do I take off Blade
I'm pretty sure from memory the blade will pull off from the front edge. There should be a black metal bar at the rear end of the blade which you can push in so the blade will pull off.
Jan 05, 2016 | Pets - Others
Have Oster model 23-51f fast feed trimmer. Took the blade off havinv trouble putting parts back together namely small copper plate approx. 1-cm long, also having trouble getting the blades to fit together...
We also have these model clippers and have found out that the modelo number has been updated to 76023-510 type in Oster professional products for more info....hope this helps
Sep 22, 2010 | Oster 76915016002 Hair Trimmer
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
CHANGING BLADES
Mar 31, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have an Oster Golden A5 2 speed. How do I
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Oct 01, 2009 | Oster Health & Beauty
How to put differnt blade on oster a-5 clipper
Sep 24, 2009 | Oster Golden A5 1-Speed Universal Motor...
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
How to sharpen oster clipper blades
In order to sharpen these blades you must first dis-assemble them (paying particular attention to the way everything fits together), Next you need to get a piece of glass or something as flat as possible and tape a sheet of 180 grit emery paper with the rough side up. Then you put the upper blade on the emery paper wih the flat side down and stroke it back and forth in a straight line at least 100 strokes each way. Turn the blade over and examine the surface with a magnifying lens to see if you have honed the blade flat all the way across. Next turn the blade 90 degrees and again stroke the blade back and forth in a straight line. Turn the blade over and examine again to see if you have removed all the first series of strokes and the new set is flat from edge to edge. If so then put that blade aside and do the same thing to the lower blade until it is flat across and up and down. After reaching this stage you need to remove the 180 grit paper and go up to 230 grit paper and repeat the whole process. After completing the second stage you progress to 400 grit paper and repeat once again..
Make sure you keep the blades straight so the hone marks are up and down and from side to side and you should have an almost razor sharp cutting tool. Also DO NOT USE SAND PAPER only emery paper or cloth. I know this sounds like a lot of work but after you've done it a couple of times you can whip out a blade in about 20 minutes.
Sep 30, 2008 | Oster 76076-010 Hair Trimmer
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Apr 08, 2008 | Oster 76076-040 Hair Trimmer
Health & Beauty Logo
107 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
