Question about Music
Digitech Vocalist Live 3 Disassembly instructions
I dropped my tuner on the Live 3 and it landed right on the LED light for the Effects circuit. It pushed the LED into the Live3. I managed to get the LED back through the hole but it appears it has separated from the circuit board as it no longer lights up - unless I press it down to establish contact. It seems like a minor repair requiring disassembly and resolder of the LED. Any idea where I can get disassembly instructions or the service manual.
danforddan1
  • 192 Answers
SOURCE: we purcased a digitech vocalist 4 a few months
your are needing to push a button that will stop a by pass. Which one ,I can not point two something I can not see. your EQ is off . try process of elimination you will find it. all so take notes as to what you have tried it makes it easeyer . I put a little pice of tape on buttons so I can remember what to push . You will get the nack of it after some fooling around. try getting a manual. youcan get them free from the MAnufacture on line.just download. good luck DFD
Posted on Apr 11, 2009
  • 5603 Answers
SOURCE: Power supply received an overload. Replaced supply
Make sure the replacement power supply was EXACT same ratings and polarity.
Posted on Sep 10, 2009
Testimonial: "Should be wearing glasses all the time as this power supply is AC, I assumed it was DC"
  • 5603 Answers
SOURCE: replacement encoder pot for a Digitech Vocalist VR rack unit?
Digikey.com and Mouser.com have encoders.
Their online catalog should help you find a replacement. Analyze how many detents it has AND the circuit board layout and number of pins.
DO NOT be surprised if you have to shorten the shaft to match the original one.
Posted on Jan 06, 2010
  • 5603 Answers
SOURCE: no vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Posted on Apr 28, 2010
M2Tech1
  • 313 Answers
SOURCE: Need a manual for the Digitech vocalist live 4 harmonizer
ftp://ftp.digitech.com/pub/PDFs/Manuals/Vocalist_LIVE2/VL2Manual_v1.pdf
TRY THIS COPY AND PASTE TO SEARCH AND THE MANUAL IS THERE>HOPE IT HELSP a
Posted on Jul 16, 2010
The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
Jun 21, 2012 | DIGITECH VOCALIST LIVE 2
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
I was using my digitech vocalist live 2 pedal during a gig 3 days ago and about 2 songs in, everytime i touched any part of the pedal or pressed the harmony on/off switch to activate the harmonys, the...
Yeah I have an idea... It is likely static electric discharge. At this time of the year we get zapped touching metal things and it also drives electronics nuts... You don't even have to feel it to get zapped.
Try using in your bare feet and see if it fusses... We had a lady vocalist wearing those ugg boots and caused static pops in her microphone... anyway try the test and if it fixes the problem, then look up Staticide spray... You can get it at Amazon.com for example... spray floor in the area you are playing on to kill the static.
The only other thing is to check if wiggling the power input plug causes the problem. Those plugs are notorious for poor connections when they wear.
Dec 28, 2010 | DIGITECH VOCALIST LIVE 2
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
No vocal sound
Apr 26, 2010 | DIGITECH VOCALIST LIVE 2
My digitech vocalist 2 is extemely noisy! the ground switch helps only partly. It seems to be bad when you first turn it on and gets worse the longer you use it.
To check for a temperature related problem, try putting it in the freezer for a while then bring it out and see if it affects the noise. If it does, then problem can be found with circuit cooler mist.
Also see if noise is affected by vibration.
Sep 09, 2009 | DIGITECH VOCALIST LIVE 2
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Music Logo
57 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
