Question about Zebra S4M Thermal Label Printer
How to reset factory default S4M. I try Pause and feed at starting the printer but it does'nt works. I have a display message: ALERT RIBON OUT.
This may be related to the printing mode you have configured. If you're printing on a thermal paper (direct) and the printer is configured for thermal transfer the printer will notify you that you are out of ribbon.
If you are printing on a regular paper and using a ribbon (thermal transfer) and the printer is configured for direct printing, the printer will notify you that you have a ribbon when you don't need one.
I hope this helps.
Regards,
Fábio
Posted on Mar 09, 2009
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Restore defaults
hold pause+feed buttons while turning on the printer. release after 10secs.
Oct 01, 2013 | Zebra S4M Thermal Label Printer
How to restore default configuration
From the user manual:Feed and Pause self testperforming this self test temporarily resets the printer configuration to the factory default values. these values are active only until power is turned off unless you save them permanently in memory. If the factory default values are permanently save, a media calibration procedure must be performed.To perform a Feed and Pause self test, complete these steps:1. Turn off (O) the printer.2. Press and hold FEED and PAUSE while turning the power On (I)3. Hold FEED and PAUSE util the first control panel light turns off.the printer configuration is temporarily reset to the factory default values. No labels print at the end of this test.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
How do I factory reset a QL420+ zebra printer?
Hello
Press and hold both the PAUSE key and FEED key while turning the printer power ON.
Release both keys anytime after the first front panel LED turns OFF.
The PAUSE and FEED keys together reset the printer to the default settings. These values
are not saved in EEPROM, but may be saved by sending the ZPL command ^JUS or
saving through the LCD on the deluxe front panel. After entering factory defaults, the
printer will remain in the paused state to let the operator know that the defaults have been
loaded.
good luck, do rate the solution if got help
Dec 02, 2010 | Zebra QL 420 Thermal Label Printer
Reset to factory default
turn off the printer press FEED and CANCEL, at the same time, tur on the printer and wait 5 secunds untill relese the buttons.
Nov 04, 2010 | Zebra S4M Thermal Label Printer
My Zebra LP 2844 printer is not aligned and the info on the tag prints onto the next tag, how do I fix this?
Calibrate the media that is in the printer. Power the printer on while holding the feed key. When it flashed red, let go. It will calibrate, print a config label, then go into dump. Press the feed key again to exit dump. Once this is complete, your printer should advance only one label at a time when you press the feed key. If this is working as expected, but the labels are not printing right when you print from you application, there is a problem with your format or driver settings.
Jan 07, 2010 | Zebra S4M Thermal Label Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Alert code
What is the message that should be display in the LCD display? The Alert light signals a problem the printer thinks it has and usually display amessage in the LCD display to help a user determine what may or may not need repair or service.
Jan 21, 2008 | Zebra S4M Thermal Label Printer
Nothing printing
I work mostly with Datamax's.
If you push the feed button does it feed and stop where it's supposed to?
Turn it off, unplugg the network ( about 5' ) turn it back on, plugg in  the network ( clear all jobs from the queu, which sometimes may have jobs in there that are frozen), do an internal test print and try to print a job.
Also try to re-calibrate the media.
Oct 01, 2007 | Zebra S4M Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
6,949 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
