Question about Conair Audio Players & Recorders
Thinner th300m : Clock only shows 24hr clock, how change to 12 hr setting?
All functions fine, but I want 12 hour clock (AM and PM), NOT 24 hr (military) clock.
  • 12 Answers
SOURCE: 24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Posted on Jul 05, 2007
SOURCE: 24 hour clock
Press and hold the time button til it flashes 12H.
Posted on Dec 11, 2007
SOURCE: How do I set the 12 or 24 hrs setting on my Casio DW 9052 casio?
when you are setting the time just hit the (g) or light button and it will switch it to 2400 time.
Posted on Feb 11, 2008
  • 29 Answers
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Posted on Mar 12, 2008
SOURCE: change the time setting from 24 hour to 12 hour AM PM
Check this
Go to start>settings
Go to the system tab and the regional settings icon
Go to the time tab and it should be hh:mm:ss tt for 24 hour clock
Let me know how that works out for you
Posted on Mar 06, 2009
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
Apr 06, 2016 | Brookstone Audio Players & Recorders
Jensen jbd-100 change clock
Take battery out and unplug to force a reset.
Hold Display until it starts flashing 12 hr
----use tuning buttons if you need to change that to 24hr
Tap Display to confirm setting and move to next stage
Repeat the same steps of tap Display and then use tuning to adjust up or down for the hour and minutes.
Make sure to increase hour setting enough to have the "pm" show up for times after noon when using 12 hr format
Nov 06, 2013 | Jensen JBD-100 UNIVERSAL BLUETOOTHR CLOCK...
How to set the time
How to set the time on what make and model device?
Mar 01, 2013 | GPS
I want to change the time from military to regular, but my bose does not have clock set just and arrow to the right and left for time
The manual is available at Bose.com and page 17-18 shows the detail.
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
May 02, 2011 | Bose Wave Radio
I do not want the 24 hr clock
here you go
here is the manual link
http://worldwide.bose.com/axa/en_au/assets/pdf/owner_guides/MusicSystems/og_wrv5.pdf
Feb 24, 2011 | Bose Wave Radio
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
24 hour clock
Sometimes if you depress both the Hr/Min buttons this toggles the time 12hr/24hr, Im not positive on this one..You can always check with a dealer or look in the owners manual if you have one. Or just learn military time..lol..
Mar 24, 2010 | 2006 Audi A4
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
Setting the time to 12hr instead of 24hr
according to my manual there isn't an option for 12 hour settings only the 24. I know, it's pretty dumb!
Mar 25, 2009 | Protron PD-DVR100 DVD Recorder
67 people viewed this question
Top Conair Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Conair Audio Player and Recorder Expert? Answer questions, earn points and help others
